Previous in Forum: Synchronous Generators   Next in Forum: How to Calculate Ampacity for a Brass Plate
10 comments
Delta Starter Diagram
12/12/2009 8:41 AM
i want star delta starter diagram,workig and circuit
Re: i ned it
12/12/2009 8:43 AM
Chek the arkives. We've ben ovr this a bazillion tmes.
Or Gogle it.
Re: i ned it
12/12/2009 8:55 AM
splchk s a wnderful thng!
CARPE CRUSTULORUM!
Re: i ned it
12/12/2009 8:58 AM
Wats splchk?
Re: i ned it
12/12/2009 12:42 PM
u dnot kown splchk ? go ask the Tiger in the woods .
spl = special, chk=
Good Answers: 58
Re: Delta Starter Diagram
12/12/2009 9:11 PM
Delta is dangerous, watch out for the high voltage leg. Don't feed it to the holding coil.
mike k
12/13/2009 2:18 AM
That would be true if you're using 120/240 delta with a wild leg, not if you are talking about 480 volt delta, which sometimes has a floating ground to allow it to keep operating in the case that one of the legs gets shorted to ground. Watch out if it is the latter cause it can bite you pretty hard if you don't know about it.
Surprise your skeptics, do what they told you couldn't be done!!
Good Answers: 170
12/12/2009 11:18 PM
Mail me thro this forum's mailbox. I will send you a copy of the power & control schematics.
12/14/2009 3:25 AM
Can it not be found in diagrams of other equipment, and be cloned from them?
12/14/2009 10:48 AM
Generally it could be, but you have to be sure that your motor's wiring diagram is the same as well as the application. Some motors even start on delta then switch to wye. I have even seen some large motors (50 hp and larger) that use an induction reactor as part of a staged starting system. There are many systems that have been used over the years with varying degrees of success. The best thing to do would be to check with the manufacturer of the piece of equipment that you have because they may have found one type of setup that works better on thier equipment than others. It's always good to be on good terms with the manufacturer's technical service department.
Good Answers: 244
02/10/2010 11:42 AM
This is a good link for Start-Delta diagram and it may help:
http://www.nhp.com.au/sprecherandschuh/common/media/technical_selection_guide/TNL-35[1].pdf
- MS
Anonymous Poster (1); electricalexpert65 (1); javelinman (2); lyn (2); mike k (1); msamad (1); not so smart (1); PWSlack (1)
You might be interested in: Circuit Breakers, Power Transformers, Circuit Tracers
