Previous in Forum: What Wire Should I Use?   Next in Forum: Load Flow and Relay Coordination Studies
LeTourneau Cranes - Main Hook Control
12/14/2009 2:56 AM
he main hook speed high and increase always Dc motor compound c6 driven by MG set
replaced speed limit and tacho generator but still same problem not ok
Re: leturneau crane main hook control
12/14/2009 3:08 AM
Contact the original equipment manufacturer directly and request a service call out visit.
Good Answers: 11
Re: LeTourneau Cranes - Main Hook Control
12/15/2009 5:28 AM
You probably have a loss of shunt field.
12/15/2009 1:47 PM
What is your location? Worked on similar M/G setups and can repair given enough time for research. Biggest trick is finding a "hands on" technician nearby.
Check your generator field control circuit. It should have a feedback loop from the generator output to a comparator that limits the speed. Depends on the manufacturing engineering.
me thinks, therefore I am - I think?
Register to Reply 3 comments
Emjay4119 (1); leskranes (1); PWSlack (1)
