Previous in Forum: Synthetic Brake Fluid   Next in Forum: Car Crashes and Check Engine Codes
10 comments
2006 Camry - Loud Tapping Noise
12/14/2009 8:36 AM
2006 Toyota Camry makes a loud tapping noise while in idle, if I shift to neutral the noise almost dissapears. What is causing this?
Re: Tapping Noise
12/14/2009 9:01 AM
Idle is a speed attribute while neutral is a gear attribute. Apples/Oranges. Need more info.
Re: 2006 Camry - Loud Tapping Noise
12/14/2009 12:44 PM
Really need more information. Shifting from neutral to a gear only changes the load difference. It's hard to tell what may be making the tapping sound without more info.
God Bless everyone!
12/15/2009 10:14 AM
The noise is worse when the car has been running for a while and is hot, as I said before the noise is only present when the car is in drive and idling, for example at a red light. If I shift to neutral while waiting for the light the noise goes away.
12/14/2009 2:13 PM
Nevermore.....
Hobbies - CNC - New Member Engineering Fields - Mechanical Engineering - New Member
12/15/2009 1:13 AM
probably a cracked flywheel if is an automatic transmission......if the motor has been run low on oil....... big trouble.
12/15/2009 9:20 AM
Two things it could be:
1. A loose or damaged torque converter/flywheel (bad news)
2. A rod knocking (very bad news)
12/15/2009 9:37 AM
12/15/2009 10:22 AM
It may be best to take it to a certified mechanic. Trying to diagnose a tapping noise without actualling hearing is next to impossible. It could be you are low on oil, a turque converter issue, flywheel issue, or any number of items. Check the easy and obvious items such as the oil level, tranmission fluid level etc...
God Bless everyone!
12/15/2009 6:41 PM
When in drive, the rpm is lower than neutral.
Oil pressure is lower at lower rpm and may not be high enough to operate the hydralic lifters. The oil is thinner when the engine is warm.
12/19/2009 11:40 PM
Check the ignition system before you condemn the car.
Anonymous Poster (5); Calnet42 (1); Franksgarage (1); jamesw (2); the wrench (1)
