A bit of a strange one here that I hope someone has some experience with. A 20MW steam turbine generator set with supervised journal bearings. The machine tripped on vibration (Y-axis of drive end generator bearing). When the shaft displacement probe was removed, it was found to be covered with a soft carbon deposit resembling soot. There is no evidence of heating in the bearing (both bearing metal temperatures <190F), nor localized bearing heating (drain oil temperature <140F), nor any "true" vibration issues (machine back online with <1mil displacement on all 8 probes). We are at a loss to explain where the deposits came from other than possibly static charges on the shaft finding a path to ground by arcing to these probes. Any other suggestions would be greatly appreciated.
