Previous in Forum: Compatible Metals?   Next in Forum: wheel friction
Thermoplastic Valve
12/15/2009 5:02 AM
Hi all,
this is my first question on this forum
we are dealing with Hydrocloric acid. we are using polyproplyne as material of pipes. I need valve dimension of 3"NPS of same material or relavant material.
Can any body help in this mater.
Pathfinder Tags: pvc valves catalogue
Re: thermoplastic Valve
12/15/2009 5:11 AM
Firstly, welcome to CR4. I've found this place to be an amazing source of information and support.
I cannot directly help you, but if you click into the "globalspec" window you will find a great wealth of information on specific components and products and there may be something there, or even a company contact to use.
You may also choose to contact your pipe supplier for their recommendations, especially when compatibility will be so important for the materials you are handling.
By the way, congratulations on having listed significant relevant information in your request.
12/15/2009 7:40 AM
Welcome:
Ryan Herco, Harrington (Not an endorsement) and others have chemical compatibility charts on their web sites.
I'd think you could find 3" PP valve with no problems.
Re: Thermoplastic Valve
12/15/2009 11:47 PM
Thanks for reply
I will check golbal spec to find any vendor
Register to Reply 3 comments
Just an Engineer (1); lyn (1); rafiullah1985 (1)
