Previous in Forum: where do computer engineers work!!!!!   Next in Forum: Modem Command Sequence
IC Data Sheets
12/15/2009 10:39 AM
Dear friends ,
Does anybody know where can i get data sheet for IC part no JCE8046.
Manufacturer is JVC ,used for XV-N412 JVC DVD player.
I have tried datasheetcatalog.com and alldatasheet.com but no result.
It`s SMD IC chip.
Thank you.
Re: IC data sheet
12/15/2009 11:24 AM
Yep. Try this.
Good Answers: 19
Re: IC data sheet
12/15/2009 11:34 AM
it's not that easy; I spend my life looking for datasheets. digchip.com is the best but you have to register - and they didn't have this one.
Re: IC data sheet
12/15/2009 3:35 PM
Some SMD supposedly because of the small size have the critical part number written on the bottom side of the package. Why would somebody deliberately do that, well nobody fixes electronics anymore, particularly SMD and only reverse engineers want to know what a part is without dismantling. Also, sometimes a large commercial consumer goods company has some parameter that they want different from an "off the shelf" JEDEC registered part. This means a new cryptic part number gets generated. Likely this gets done for the exact same reasons I mentioned before.
Re: IC Data Sheets
12/16/2009 11:10 AM
It's also possible that it is a proprietary ASIC in which case you will find nothing unless you work for JVC.
Good Answers: 68
Re: IC Data Sheets
12/16/2009 5:20 PM
Hi kumarr68,
I have found what appears to be what you want, but I am unable to get to the site because it asks for for my username and password. But does not allow me to register.
If you or anyone else can solve this I would be grateful to know?
  1. SCHEMATIC DIAGRAMS - 13:52Note: If the voltages are not indicated on the schematic ... 2) Indication on schematic diagram. Voltage indications for REC and PB mode on ..... JCE8046-X ...
    region.cepco.ru/other/JVC/DVD/XV-N412S(B,E)/yd029sch.pdf -
You have removed results from this search. Hide themLoading...
babybear (1); Brave Sir Robin (1); HUX (1); PWSlack (1); redfred (1)
You might be interested in: IC Modems, IC Timers
