Previous in Forum: Some help finding a Powered (pneumatic?) Linear Displacement Sensor/Probe?   Next in Forum: KIDDE Fault
ASTM Standard Needed
01/16/2007 12:09 PM
I approached a manufacturer for Dom Hex Bolt Gr 12.9 with Square Nut Gr 10 & Plow Bolt Gr 10.9 . They in turn are asking what is the ASTM or equivalent standard applicable. My required items are fasteners for heavy equipments. Can u please help advising the standards such as ASTM/ SAE etc.
Good Answers: 27
Re: ASTM Standard Needed
01/17/2007 9:07 AM
If those are legitimate fastener grades, the fastener manufacturer should be aware of them. I don't recognize them as ASTM or SAE grades but there are several other MIL, ANSI, ISO, AAR, Federal, etc. standards that may apply. As I recall, plow bolts are covered by ANSI B18.9.
You had a reason for specifying those grades, recommend you go back to your customer or source for a lead to the standards organization.
Might also check IFI (Industrial Fasteners Institute).
Good Answers: 137
01/18/2007 4:16 AM
These are ISO standards. The 12 and 10 are 1/10 of the minimum UTS of the material in kgf/mm2, the 9 is 1/10 of the ratio of minimum yield stress to minimum UTS, as a %. So minimum UTSs are 120 and 100 kgf/mm2, and minimum yield stresses are 108 and 90 kgf/mm2, the
120 kgf/mm2 = 170680 psi = 76.2 ton/in2
100 kgf/mm2 = 142230 psi = 63.5 ton/in2
108 kgf/mm2 = 153610 psi = 68.6 ton/in2
90 kgf/mm2 = 128000 psi = 57.2 ton/in2
These are high-tensile bolts, only stronger grade in data I have is 14.9. As others have pointed out, this strength is likely to be used for a good reason, and I wouldn't risk a lower grade without being sure it's OK.
You might be interested in: Bolt Tensioners, Bolts, Durometers
