Previous in Forum: What is the Best Choice for CAD/CAM Software?   Next in Forum: ASTM Standard Needed
Some help finding a Powered (pneumatic?) Linear Displacement Sensor/Probe?
01/16/2007 10:27 AM
I am looking for a Pneumatic (or otherwise powered) Sensor/Probe that will detect linear displacement.
Heres the application: An I-beam will be worked on by an automated plasma cutter. The beam needs to be measured in order for the plasma cutter to work, and it takes a long time to measure using the tool itself. We need two powered probes that will drop down from a bridge to touch the i-beam, and return the displacement.
Thanks for the help
Re: Some help finding a Powered (pneumatic?) Linear Displacement Sensor/Probe?
01/16/2007 10:54 AM
Why not a laser? There are lots of laser sensors on the market.
01/16/2007 10:57 AM
We looked at lasers, we need an accuracy of around 2 thou at 20 inches, it's impractical for a laser.
01/22/2007 2:33 PM
How about an ultrasonic sensor?? Some Banner ultrasonic sensor can detect up to 3m. With a little modification to the circuit, you would probably do it.
MidniteFighter
My mind is full of useful knowledge, I just don't know how it applied.
01/22/2007 2:43 PM
Ultrasonic is used for proximity sensing, it's not nearly accurate enough for this application, we have gone with pneumatic cylinders with internal LVDTs which give a resolution of around 5 micrometers, thanks all for the suggestions.
08/22/2007 6:02 PM
If anyone found a solution I'd be interested also. Linear displacement down to a thou over about 48 to 60 inches if possible.
I thought of getting a scale scribed into something thermally stable and having a screw driven control provide incremental offsets between scribed marked (i.e. the scribed mark optically confirms EXACTLY where the 18 inch mark is, then a stepper motor provides + or - granular control from there.)
Any other thoughts or comments?
Anonymous Poster (1); Kirk (2); ManDownUnder (1); MidniteFighter (1)
