Previous in Forum: Cables vs. Bus Ducts   Next in Forum: Indesit No-Frost Fridge
Ring Main Gear vs Ring Main Unit
12/16/2009 1:28 AM
what is a diiference between Ring main Gear & Ring main Unit in Electrical HT side ?
User-tagged by 1 user
Good Answers: 170
Re: Ring Main Gear vs Ring Main Unit
12/18/2009 8:43 AM
A Ring Main Gear is the switchgear in a Ring Main Unit. And the Ring Main Unit is the assembly of one or more Ring Main Gear.
01/01/2010 1:29 PM
This might not be relevant, but I have done consulting, commissioning and maintenance on various different types and makes of RMU's (Ring Main Units). I have recently come across an Ormazabal unit, and was very disapointed in the workmanship and lack of information provided with the unit or from their website.
In general, these units are a low cost answer to (usually) ringmain supply and protection. It contains self-polarizing relays, which uses the current from the CTs (or in some cases it is a sensor) to power the relay. Tripping is also done via a circuit internal to the relay that produces a DC tripping current for the trip coil. On this specific Ormazabal unit, there are no indication of what the trip coil rating are.
The CT's (or sensors) must be matched with the protection relay, as some of the units cannot select different ratios and I have found on numerous occations that this has been mismatched which results in wrong primary current readings and incorrect grading as any setting applied will be incorrect.
Just a bit of useful info...
09/02/2010 4:25 AM
Hello, I work for Ormazabal in the Marketing Department. Although I am not an expertise in technical issues, I finished my Electrical Engineering degree a couple of years ago. I would really appreciatte if you could give us some more information about the product you are referring to and the precise reasons why you consider there is a lack of quality. Also, what sort of information do you consider should be included in catalogs and the website and could be usefull for our customers/installers,etc?.
Our manufacturing facilities in Spain are quite well automated, and many our devices have been quite a long time providing service in offshore winfarms and clients are happy with them and the solutions we offer.
Thanks for sharing your opinion and hope hearing from you soon.
06/22/2016 6:14 AM
Ring main unit in electrical power distribution is a standard piece of switchgear comprising of switches for switching power cable rings of switches in series with fuses for the protection of distribution transformers. Ring main gear which includes all the switching devices associated with mainly power system protection. It also includes all devices associated with control, metering and regulating of electrical power system.
Control Panels India
DGG2010 (1); electricalexpert65 (1); FreddieM (1); highvoltpower (1)
