Previous in Forum: Modem Command Sequence   Next in Forum: Website for Electronic Components and Circuit Drawings?
How to Write a Windows Serial Interface Script File
12/16/2009 11:24 AM
I need to write a scrpit file to communicate through a serial port in Windows. It may be in the form of a window with a few radio buttons to output different blocks of code, it will interface a PIC micro to eventually test a relay matrix. Could anyone offer any pointers as to how I could go about this? The Pic code is already written and all I need to do is output ASCII characters to switch the relays (I think). I'm sure it's quite simple but if you don't know, you don't know.
Also posted in: also posted in Software & Programming
Re: I Need to Write a Windows Serial Interface Script File
12/16/2009 1:11 PM
I found an old version of Hyperterminal that I use for some simple commands. If you need to send strings you will have to wirte an app. If your familiar with C,C++ or visual C, I can send you some of my source code.
United Kingdom - Member - Hobbies - HAM Radio - G7TSP Engineering Fields - Electrical Engineering -
12/17/2009 3:35 AM
I have used C in the past, having a look at your code would be useful thanks...
cleman@drallim.com
Good Answers: 52
12/16/2009 1:43 PM
I was able to do this in visual basic, it took a little searching to find the correct commands to sent output to a serial port, but after that it was quite easy. My use was also as an output for a PIC micro as a test program to setup and test my project. Here is a link with some code that does look sort of familiar. If you don't use VB this won't be much help, but I was able to piece together what I needed with this.
12/16/2009 3:25 PM
Cool! PIC's are allot of fun and extremely powerful. I was playing around with the Microchip PICkit 1 Flash Starter Kit. There was a 4 part contest last year with the PIC chip. Many cool ideas and inventions.
Good Answers: 213
Re: How to Write a Windows Serial Interface Script File
12/16/2009 11:15 PM
Try this:
http://www.techtutorials.info/winscript.html
12/17/2009 3:47 AM
Try
www.windmill.co.uk
They have a newsletter with some good tips and also have a program for serial communications
Tony
Tony Aston
Good Answers: 70
12/17/2009 2:50 PM
Some later versions of VB can send commands thru serial ports. For a few hundred dollars WinWedge by TALTech will do it for you, at least for the RS232 port.
www.taltech.com/products/winwedge.html
cwarner7_11 (1); frankd20 (1); johnfotl (1); Lemmy70 (1); Slowpokee (2); Tony Aston (1)
