Previous in Forum: Grounding Parallel Generators   Next in Forum: utilisation factor.
13 comments
DC CT
12/17/2009 2:17 AM
hello all,
anybody know about the dc ct?
application or tch details or upcoming ??any..
is it appilded for Traction system??
Re: DC CT
12/17/2009 3:09 AM
<...dc ct...>
A direct current, current transformer? Wow - that would be novel!
Aren't shunt bypass ammeters used anymore?
Re: DC CT
12/17/2009 4:07 AM
FOR PLASMA RESEARCH IT'S THOUGHT GOING UNDER PROCESS AND SOME U.S JOURNAL ALREADY PUBLISHED (PREVIOUSLY)
BUT APPLICATION..NO IDEA...
Re: DC CT
12/17/2009 4:15 AM
May be you want to get "shunt resistance" instead of DC current transformer.
RSM Elect Specialist
Re: DC CT
12/17/2009 7:59 AM
You can use the shunt resistor,
You can refer the mltimeter ( Having 20A range) phenomina
Re: DC CT
12/17/2009 8:07 AM
There must be a full moon. The loonies are out in full force.
Re: DC CT
12/17/2009 8:22 AM
guest: check out hall effect devices, I have a bell dc clamp on amp meter, also try RMS instruments. perry
Re: DC CT
12/17/2009 8:42 AM
You know there are DC non-contact measurement is possible. And infact it might not always use the hall effect.
The DC current does produce a magnetic field around the conductor. In case of DC this field is to be measured at a certain distance that's all.
In a method I know, this si used to saturate specific type of magnetic material. Then the excitation current is superimposed over it till the core saturates. The difference is proportional to the primary current. The problem is the effect of the permeabilities of the media in between. But that is again the basic principle of the DC-CT operation.
Some details may be somewhere on net. That OP must try to find.
Then we have this with brief principle already in market.
Re: DC CT
12/19/2009 4:57 PM
And more this type of measurement used in DC transmission and measuring field current of a Generator under brushless excitation systems..
India - Member - New Member
Good Answers: 164
Re: DC CT
05/17/2010 11:43 AM
Better late than never .. please check this out ..
DC CT Patent
Good Answers: 804
Re: DC CT
12/17/2009 3:50 PM
There are a number of mfrs using the term DCCT out there, referring to Direct Current Current Transducer, when describing their Hall Effect transducers. I agree this is a bastardization of the accepted common use of the term "CT" meaning Current Transformer", but it is what it is.
Good Answers: 170
Re: DC CT
12/18/2009 8:26 AM
Any CT will work if DC is pulsating. Only 'pure DC' is problem.
Re: DC CT
12/18/2009 9:00 AM
"Pure" DC? As in virgin DC? Hah, just try to find some...
Good Answers: 170
Re: DC CT
12/18/2009 9:35 AM
I am sorry about the terminology! But that's how we were taught in early eighties. I meant "Ripple-free" DC.
anand.mandarapu (1); Anonymous Poster (3); electricalexpert65 (2); JRaef (1); k.dhana (1); kvsridhar (1); lyn (1); perry (1); PWSlack (1); rasam.syamsudin (1)
