Previous in Forum: Working Stress Analysis Procedure for Fully-Encased Concrete WF Beams   Next in Forum: Peltier / thermoelectric module.
21 comments
Mechanical drawing/drafting programs
12/19/2009 6:09 PM
Several months ago there was a thread on drawing programs; I have taken a quick look at these. Is there anything new on the market that you have used and can recommend? I do not need the power, size, and expense of something like AutoCAD; but would like something fairly simple and hopefully free.
It looks like one called Cadstd.com may be in the ballpark. Are there any other suggestions?
Thanks.
Lehman57
Re: Mechanical drawing/drafting programs
12/19/2009 7:28 PM
I down loaded DoubleCAD XT the other day. It looks like AutoCad. Haven't had a chance to use it much. It's free. Looks OK.
I've played with Cadstd too. I'll go with DoubleCAD myself. But, I'm just a casual AutoCAD LT user at work.
Maybe the experts have opinions too.
Good Answers: 143
12/19/2009 7:31 PM
What are you doing with it?
12/19/2009 11:22 PM
Relatively simple 2D drawings with dimensions. Lines, circles, arcs, etc.
My first project may be a part that I need for a WW2 OCD trailer pump that looks like a very large Belleville washer--4" diameter, 7/16" thick, no center hole. So, side view would have lines and arcs. Plus the dimensions and notes.
Lehman57
12/20/2009 11:23 PM
You might want to also look at the free Google sketchup for illustrating your device. It works with lines and surfaces instead of extrusions, but it makes it easy to rotate, position and duplicate your part.
Good Answers: 213
12/19/2009 11:25 PM
DoubleCAD has been the solution I find most compatible with my needs...Price is right, as well.
12/20/2009 10:39 PM
Hobbies - HAM Radio - VE6LDS Popular Science - Weaponology - New Member Canada - Member - New Member Engineering Fields - Nuclear Engineering - New Member
12/21/2009 12:04 AM
Do a google on Allycad, they have a free version and the only restriction is on the design file size. It includes bunch of tookits and a programmable macro language that is quite basic like. It is a south African company.
Semi-retired systems analyst, part time Ham radio operator, full time grandfather.
12/21/2009 6:41 AM
Dah-Dit-Dah-Dit Dah-Dah-Dit-Dah.... good one Grandpa... I am a Great GPA.. hehehe I miss the Morse... sad eh..?
Dit-Dah-Dit Dah-Dah-Dah Dah-Dit-Dit Dah-Dah Dit-Dit-Dah Dah-dit Dit-Dah-Dit Dah-Dah-Dah
12/21/2009 7:43 AM
I recently downloaded doublecad. I have just experimented with it a little bit. I have used autocad lt for many years. It seems to be pretty good and comparable to the lt version of autocad, even with some better features. I downloaded it mainly to try for at home use and to be able to open newer versions of autocad drawings that my older autocad lt would not open. I can now open newer versions and save them down to work with my 2002 autocad lt version.
12/21/2009 8:04 AM
All mentioned, DoubleCAD it is good and Free!.
12/21/2009 9:24 AM
Solid Edge draft is free you just register but they do not bother you and it is the draft pkg. to it's 3D program. Also it is the easiest (user friendly) drafting by being able to click without typing
12/21/2009 9:30 AM
Just curious, if a person sent an AutoCad 14 dwg to a person with AutoCad LT (or Cadstd, or one of the others), would they be able to open it? Or visa versa?
Good Answers: 119
12/21/2009 4:53 PM
ACad 14 to ACad LT - very probably, if LT is a newer year/version
ACad LT to ACad 14 - unlikely, Autocad stuff is never backward compatible
Many many other cad programs can open AutoCad dwg files. Not all others will export dwg files for opening in AutoCad.
DXF format is usually the preferred transfer format in that case, and very often they are not backwards compatible.
Hooker
12/21/2009 9:49 AM
Hello,
A nice and not expensive cad solution is the WZCad is very similar to Autocad and very easy to use.
you cud found it at: http://www.zwcad.org/
Regards to all
and Mery Christmas
Carlos Martins
12/21/2009 10:02 AM
There is a free program out there called "TrueConvert" from Autodesk that works well to convert Autocad drawings from one version to another
12/21/2009 12:59 PM
Alibre;Truespace;brlcad;...;Why not Google Sketchup?
12/21/2009 2:52 PM
Try Delta Cad www.deltacad.com
It is about $40 and very powerful. We have been using for years very successfully. Easy to learn / master. Does about 95% or more of what AutoCad LT does for a fraction of the cost.
I have recommended to several others and they love it.
12/21/2009 2:53 PM
Try SolidWorks 3D
www.solidworks.com
E pur si muove -- Galileo
12/21/2009 6:08 PM
VectorWorks is an excellent CAD program available for Mac + Windows OSs. Not free but very reasonably priced and a very shallow learning curve. Look here: http://www.nemetschek.net/
The basic package has all the capability you want + it is an integrated 2D - 3D environment - you draw an element in 2D and if you enter the Z component in the Layer definition it converts to 3D automatically. Believe me - you will want the 3D capability sooner than you think.
Does not have the machine design power of SolidWorks but you do not want that complexity or price.
A little knowledge is a dangerous thing, Drink deep or taste not the pyrenean spring.
12/21/2009 8:40 PM
Alibre is a 3d solid modeling CAD system that also does a good job of producing 2d drawings from the models parts.
I have used it for years and find that it is fast to learn and use and robust enough to keep expanding with your growing capabilities as an engineer/designer. Its not free, but it is very reasonable.
It is so very nice to simply download 3d models of the standard parts you want to spec. copy and past the cost and other data and draft your custom components out of solids or sheet stock and then assemble the whole thing electronically to debug the design without investing anything more in the design than the time it takes to create it.
I am a very happy customer.
Mr. Gee
01/14/2010 11:25 AM
Goggle Sketch up.
I have used autocad for 15plus years, started 3d work about 10yr ago. Sketch up is very intuitive and easier than acad.
Register to Reply 21 comments
Anonymous Poster (2); atsysusa (1); Craigsat (1); cwarner7_11 (1); ferquiza (1); FLIPFLOP (1); flyinghigh (1); Frank12 (1); freemanpr (1); Hooker (1); israelkk (1); Jbeebs (1); Lehman57 (1); Limnerlad (1); lyn (1); Mr Gee (1); tcoulson (1); The_curious_one (1); tjs12 (1); TVP45 (1)
