Previous in Forum: MS-DOS Commands   Next in Forum: PC Games
13 comments
United Kingdom - Member - British
PC Sound Not Working
12/21/2009 1:05 PM
I was wondering if there is a logical explanation to sound not working some times when you turn the pc on, and it working other times. It was happening on a Dell Dimension E520, so I put in a sound card, which worked fine for a few weeks and then the problem started with that too. I am unsure whether it is a driver issue, or could it be linked to a faulty PSU? Then again, I don't use the pc, so it could go down to user error. What do you think?
bondy111
Re: Sound Not Working
12/21/2009 3:38 PM
Don't Dell usually ship with their own diagnostic stuff loaded ? If not, the user should be able to find it at Dell's web-site. Some of the free utilities such as Iobit Advance System Care might be able to help. Not being silly, but it could be something like a manky cable to the speakers - been there/done that().
12/22/2009 8:35 AM
Also the sound card may have moved and come out of the slot.
Re: PC Sound Not Working
12/22/2009 9:24 AM
I do not know if this helps, but, I use Go To My PC to access my work computer from home. When I access the work computer, the sound gets muted and I have to turn it back on.
12/22/2009 9:32 AM
Check your default settings. You may have one application that works from a different audio device than your default, such as iTunes or something like that. You may be able to run an application that works because it is using a different audio device and then when you run another application it won't work because it is not the right audio device for that application. I am tranferring LP records from vinyl to my computer and it uses iTunes but that was not my default device. Once I did that I could play the music on iTunes but my other stuff would not work. At first I thought I had something wrong with my speakers or my sound card or something, but I changed the default device and everything works again.
Jim
12/22/2009 10:56 AM
Thanks Jim, but the sound either works for everything or doesn't work at all. It is straight from start up that it either works or doesn't.
bondy111
12/22/2009 7:40 PM
When the sound isn't working check the icon for sound and see if the sound is muted or is indicating it is working. I found that my old Dell was doing the same thing as it would turn off the sound and save that state when closing the windows. Upon starting again the sound would be muted or off.
Anything can be made, sometimes at great expense, resulting in greater satisfaction, :)
12/23/2009 4:20 AM
No, it's not muted. I check that every time, to try and show the user is a bit of an idiot :D
bondy111
12/23/2009 4:21 AM
I disabled the sound via the BIOS and then it showed as disabled in the hardware manager.
bondy111
Good Answers: 97
12/23/2009 12:48 PM
Tried patching or bypassing the onboard speaker terminations to an outboard? Is there crud in the headphone jack connector or are any of these connections faulty, past their prime etc.?
12/23/2009 4:17 PM
No I haven't tried patching, it's not the onboard speaker sound that doesn't work. The headphone jack and plug are clean. I don't think they are faulty, and are both almost new.
bondy111
Good Answers: 97
12/23/2009 8:03 PM
Oh okay, The speaker makes sound then what sound feature is giving you trouble? Is it the BIOS post beep you're not now hearing?
I'm quite puzzled....oh is it no sound through headphones?
Sometimes my computer will fudge and I need reset the headphone in the configuration.
12/24/2009 5:26 AM
It is the external speakers that don't emit sound sometimes, when the pc mucks up.
bondy111
Good Answers: 97
12/27/2009 1:49 AM
Check the header connection on the MB...
Register to Reply 13 comments
Andy K (1); Anonymous Poster (1); Bondy111 (5); bwire (3); Jim Cartwright (1); Mechanicalmark (1); RicinCinci (1)
