Previous in Forum: CSA / UL Approved PAT Testers   Next in Forum: Testing a Thyristor
11 comments
Analog Joystick
12/21/2009 5:05 PM
We recently purchased Joystick for crane which is analog type. Is it necessary to fill the oil inside the analog potentiometer?? Without filling oil can we use it...
purushmicro
Re: Analog Joystick
12/21/2009 6:37 PM
What do the operating and maintenance instructions say?
I have never come across an analog joystick that requires oil! (is it a purely mechanical analog joystick?)
Good Answers: 804
Re: Analog Joystick
12/21/2009 7:02 PM
As a general rule, anything that goes to the trouble to be oil-filled, MUST be oil-filled. If one is designed that way, other aspects of the design would likely be compromised if the oil was not present.
There are plenty of joysticks out there that are not oil-filled and only a few that are, so for someone to have chosen one that is means they must have had a very good reason to spend all that extra money. Generally, using a device like this would be necessary if there were risks of contamination, explosion or some other environmental limitation that required the oil.
Re: Analog Joystick
12/21/2009 7:20 PM
Isn't it already filled and sealed?
Or, is there a dipstick?
Location: Currently on break at home in Houston, Texas USA
Re: Analog Joystick
12/22/2009 11:10 PM
The purpose of the oil is to create resistance to the mechanical input or dampen the movement of the joystick thereby making the operation and the output signal smoother and more uniform. The oil is not mandatory but recommended. Any silicon-based oil will do.
Re: Analog Joystick
12/23/2009 5:45 AM
I did a little research and found that a silicone oil having a viscosity of about 300,000 to about 900,000 cstokes is recommended. I would check with the manufacturer for their recommendation.
Again, the joystick can be operated without the oil but you may experience a "tremor effect" associated with any un-dampended joystick.
Re: Analog Joystick
12/22/2009 11:38 PM
Fill er up!
Bin there, done that, then done that again and again and now I forgot where I was.Is this what it means to get old?
Re: Analog Joystick
12/23/2009 5:29 AM
If the instruction manual says fill oil,then fill oil.U may also contact yr customer or rather the manufacturer for clearification. Patrick Whowha
Patrick Whowha
Good Answers: 42
Re: Analog Joystick
12/23/2009 3:31 PM
captivating blue eyes!
Re: Analog Joystick
12/23/2009 10:48 PM
instruction manuals are the best in this case. We do carry a line of analog joystick which are NON CONTACT type. It provides excellent results with long life, no pot to wear out. you may contact me for further discussion at 905 693 2991 Joe
Re: Analog Joystick
12/25/2009 8:55 AM
As previously mentioned, the oil is probably a dampening mechanism;like an oil filled guage dampens vibrations.If this joystick is in a high vibration environment,or very loud environment, it could prevent spurious movement of the crane, which could be disasterous in certain circumstances.The radio dial on old radios had a heavy tuning wheel,to make it easier to resolve a channel in close proximity to other channels.Some weigh scales also have oil in them, it is called a dash pot.This allows the needle to settle quickly to a stable reading.Some old electrical relays also had dash pots, so oil for dampening is a very mature technology.The joystick you mention must be very sensitive for dampening to be required.The upside of this is very good tactile feel when making minute adjustments.The actual element internally that produces the signal in not relevant.It can be a simple potentiometer,or a quadrature generating pulse generator, either optical or magnetic/hall effect.
Ths long and short of it is this:If it came with oil, and it is leaking, and there is not a provision for adding oil, it has a defective seal somewhere.Replace/repair it.If it has a fill port, consult the manual for instructions.
HTRN
Re: Analog Joystick
12/30/2009 7:48 AM
Thanks for the information!!!
purushmicro
Register to Reply 11 comments
Anonymous Poster (1); GW (1); HiTekRedNek (1); jack of all trades (1); JRaef (1); lyn (1); MIKE L. (1); Patrick Whowha (1); purushmicro (1); tropicalspeed (2)
You might be interested in: Oil Sensors and Analyzers, Oil Skimmers
