Previous in Forum: What's the Best Type of Pump for Diesel Transfers?   Next in Forum: ASTM Equivalent to C80 Steel
9 comments
Wanted: Wooding Shearing Machine
12/22/2009 4:52 AM
Dear Team, Looking for a shearing machine to cut blocks of between 50 to 70 mm from fiberous tree trunk of 3 feet in length and 3 feet in diameter, preferably clean cuts. TQ, GJ
Do visit our web site for Palm Oil Mills and Plantation Management
Re: Wooding Shearing machine
12/22/2009 6:14 AM
Shearing a 3' diameter log doesn't sound feasible to me. I'd suspect a sawing motion is needed.
12/22/2009 11:20 AM
Hello, ramofpersus.
I agree with Del... most of us usually do. Shearing or slicing a flitch 50mm+ will almost certainly crack the sheared piece.
Here is a pretty good data sheet for sliced lumber:
This from the AWI handbook.
Sawing should produce the thickness you indicate with little trouble.
12/22/2009 3:59 PM
Boy, that didn't come out so good.
I'll see if I can clean it up a little, and post it again.
12/23/2009 2:39 AM
Thank you for the info. We have detail drawing of the machin, could not send as attachement with this mail. Will send under personal mail to those interested in manufacturing this machine.
12/23/2009 5:52 PM
Have you investigated equipment and machines already available, and not found something that will work for you?
If you wish, you can send me an internal message and I will be happy to have a look for you. I do not manufacture machines, but have been around plant equipment for wood doors, and may be able to suggest something.
12/24/2009 6:14 PM
Thank you, please provide your email address for direct communication.
12/29/2009 9:03 AM
There is no need. Use CR4's messaging system instead.
http://cr4.globalspec.com/thread/45769/Why-You-Shouldn-t-List-Your-Email-Address
Re: Palm Oil production equipment
12/29/2009 10:56 AM
Thanks, PWSlack. I have corresponded with ramofpersus through the internal mail at CR4, and we have traded a few emails thru the internet as well.
As an update to this thread, in the vernacular of the palm oil business, 'Wood Shearing' is the process of removing the fruit bunches from the woody stalk of a palm branch. The OP is looking for assistance in this area, not slicing lumber as Del and I had interpreted his question. As I have nothing to offer him about this, I advised him to post again, with a differently worded question.
Re: Wanted: Wooding Shearing Machine
03/12/2010 8:54 AM
we are a manufacturer of shearing machine and our web is www.shearingmachine.org
Register to Reply 9 comments
Anonymous Poster (1); Doorman (4); PWSlack (1); ramofpersus (2); user-deleted-1105 (1)
