Previous in Forum: 330V 25mA   Next in Forum: Thyristor Duty Transformers
Good Answers: 29
Solar Substitute
12/22/2009 12:30 PM
I'm designing a Flare gas flow monitoring system that operates via 24V photovoltaic cells and a charge sequencer and I need an artificial light source during development and hopefully follow-on builds. These are BP Solar cells. Any suggestions?
Re: Solar substitute
12/22/2009 4:13 PM
Do you not have access to a window or roof?
You can use artificial light but it won't give you an accurate representation (unless you use a lot of it and take care to simulate sun movement and cloud cover which will cause the generated power to vary by quite a bit). You may be better off simulating the solar panel output using estimated power characteristics and de-rating factors.
Hobbies - Hunting - Deer and Birds Hobbies - HAM Radio - Achieved Ham Radio license in 2008 Hobbies - Fishing - Fisherman United States - US - Statue of Liberty - Know freedom, no tyranny.  Know tyranny, no freedom. Hobbies - DIY Welding - Beginner
Good Answers: 19
Re: Solar Substitute
12/23/2009 4:01 PM
Buy a DC low watt light and wire directly to your charge controller/seq. My favorite supplier is at www.backwoodssolar.com (note woods is plural, so two ss together)
Matt
Go green, use a solar powered light saber...
Register to Reply 2 comments
You might be interested in: Photovoltaic Cells, Solar Water Heaters, Solar Mounts
