Gretings!
The title refers to the voltage needed for my tube preamp (quad22) that was born without power supply. I have a trasformer that has a secondary 640v CT and 6v.
Can you think of a way to rectify the 320+320 and end up with about 330 volts? Oh, the primary has also the 220 volts tap. I thought I would try to use it and get about half at the secondary but then I lose the filament heater. If I rectify full wave using a bridge from 320 vac I get around 448 vdc. Ouch.
P.S. I would not like to use a tube rectifier UNLESS it would make things easy.
Thanks and Happy Holidays to all of you.
