Previous in Forum: Deburring of Crankshaft timing sprocket.   Next in Forum: Hardening Steel Plates
21 comments
Sourcing Manufacturing from China
12/22/2009 4:00 PM
Hi Guys,
I am looking for some "CR4 Recommended" manufacturers in China who would be able to make a part for me.
The part would be out of a 9" diameter piece of 1/8" think FDA approved buna-n (nitrile), with a 60 shore A duro. The piece would have various features cut into the inside diameter.
The process would most likely stamping or cutting (h20/laser). First couple of runs would be smaller quantities (200 pcs). But different sizes and patterns for the cut out would be required.
I have tried a few of the web based sourcing sites but have been burned on that route.
Any suggestions or ideas would be greatly appreciated.
jj
Re: Sourcing Manufacturing from China
12/22/2009 5:19 PM
Check out some of the registered members on this site and contact them through email.
Could be Waterjet also. You may see problem because of the low runs. I suggest advertising the job on some of the internet jobber marts.
p911
12/23/2009 8:04 AM
Ultrasonic cutters don't have the pollution problems associated with waterjets and plasma cutters.
"We cannot sow thistles and reap clover. Nature simply does not run things that way. She goes by cause and effect." Napoleon Hill
12/23/2009 8:20 AM
You have not seen a waterjet run or applied correctly.
As far as pollution. Have you every worked near ultra sonic cutter. Noise is a pollution also.
p911
12/23/2009 10:07 AM
It is easier to control noise pollution than it is to remove the pollutants from the air or water. Also, noise pollution is localized within the plant or can be controlled at the source through fairly inexpensive equipment or sound absorbing walls. Air pollutants will be vented to the community through the buildings air vents and doors. The metals in water contaminate the community's drinking water. Air and water pollutants cause cancer, birth defects, and other problems for the community and workers. Noise pollution generally only harms the workers through hearing loss. Hearing loss has a smaller risk factor since death isn't an end result. As for cost, PPE is much less expensive than purchasing and operating the appropriate pollution control systems for air and water.
The ultrasonic systems that I have seen in use were surrounded by a noise absorbing barrier to protect the workers. The levels were well below the threshold for PPE requirements in the US (OSHA regulations).
The last plasma cutter that I visited had indoor air quality problems and vented the fumes into the community to help reduce the problem. The water cutting operations at the facilities I have helped had large wastewater pretreatment systems to meet the discharge requirements for the municipal wastewater treatment plants.
Dollar for dollar, noise is a better pollutant to deal with than air or water pollutants.
12/23/2009 11:09 AM
Your quite a proponent for ultrasonics..............do you really think ultrasonics is the best choice for this, with the information given.
I too have experience with ultrasonics for practical uses. The material instead of cutting may absorb the energy instead.
As far as listed the best procedure, Its good to give some options, but to eliminate options it on the basis of contamination without considering the pros/cons is not wise.
As far as contamination such as what the waterjet produces, we had the waste material tested for heavy metals to see if it could go into a landfill. It passed.
But is it the best choice? No, not for me to decide.
But you do have a right to your opinion and choices.
p911
ps, I looked at your profile and understand your take on the matter........interesting. do you realize the pollution that is emitted doing layups of fiberglass for the?
Will that stop you from kayaking?
12/23/2009 12:01 PM
First, I wasn't trying to attack your first post. I was only adding other options. For the OP, ultrasonic may work. Don't know without more info.
Second, in my position, I only provide the opportunities that are considered cleaner and safer to manufacturers. It is up to the company to determine if the technology meets all of their needs and their budget. My agency does not regulate noise, but I do have a good understanding of noise pollution and OSHA requirements. Most of the Pollution covered in the Green Manufacturing Specialist Certification I just completed was based on noise. Examples of questions I would ask your facility: Can this be done in a way that doesn't produce any wastes (air emissions are waste)? How much is your company spending to landfill or dispose of that waste? How much money is spent on wastewater treatment materials? How much energy are you using to pump for the entire process including wastewater treatment? Is that counted in the cost per unit analysis completed by your management? Do you produce enough for a metal recycler?
As for white water kayaking, you missed the emissions from my car, the Yakima factories that created my roof racks, the helmet manufacturer, pfd factory, paddle (vinyl) factory, my dry gear and neoprene gear, and don't forget the fast food companies while on those trips. I do fully understand it. I wish I had the opportunity to make kayak manufacturing more sustainable, but the manufacturers are in other states. I do think it is better than having a 20ft speed boat with a 350 inboard pulled behind a truck with a big V-8. Not everything in life can be "Green". Sometimes there are better alternatives that meet our individual needs and sometimes there are not. E.G. I carpool to almost every kayaking trip and camp in a tent without electricity. I no longer buy bottled water or canned soda. We purchase whole foods or bulk items (reduced packaging). I could assess my lifestyle and you would find that other than replacing the coal fired power plant, I have done as much as I can to reduce my footprint and nothing I do compares to the power plant.
12/23/2009 12:24 PM
I didn't take it as an attack only a discussion
For the water jet it costs about $150.00/month, to remove and dispose of the material from the tank, and this is with it running about 60 hours a week. Total, pumping and disposal.
The energy for the waterjet is quite extensive, 60HP intensifiers. It takes time to cut 3" material as compared to a plasma, one has to decide on the process.
Consumables such as garnet, that gets pumped, and the tooling, the ruby or diamond would last 75 - 200 hour respectively, mixing tube 50-150 hours, do not have the costs at the moment.
I had designed using ultrasonics to cut food stuffs, other than that it was used for welding plastic such as seams on baby diapers.
BTW I'm from Wisconsin
You also pointed out some things that most posters forget about green manufacturing, and thats the carbon footprint it take to put the infrastructure in.
Its the numbers that one has to look at, individual no, population as a whole, big effect.
p911
12/23/2009 12:59 PM
Great discussion! Have you thought about starting a thread on differenct cutting technologies, costs, wastes, pros and cons? I most certainly would be interested especially with your plant as an example.
12/23/2009 1:05 PM
have to see what past discussions on CR4 is first.
12/22/2009 5:48 PM
Steel rule dies are the ticket for shout runs. I'd do those here in the US. Then send the volume off shore, if you must.
Check out: Search GlobalSpec , the sponsor of this site.
12/23/2009 12:17 AM
CR4 has recorded several chinese product problems. Avoid it totally.
12/23/2009 8:54 AM
Could not agree more.
12/23/2009 9:13 AM
I can get you a smoking deal on some Chinese drywall!
12/23/2009 10:00 AM
Try cntsales@live.cn
Her name is Amelia Hu from CN Plastics. She's really nice and helpful. I've had her quote a specially made part one time and have remained in contact with her every since.
Tell her that Robert Karp referred you.
12/23/2009 11:18 AM
Just for the Nay sayers about outsourcing to China.
CN Mould and Plastics does a lot of contract work for mass production of products for American Companies.
They are a high tech company. They will also furnish you with information about the company that includes pictures and video for an introduction.
There are quite a few Chinese based companies that are up to speed with American Standards and others are working to get up to speed. They don't want to be considered a second rate manufacturing country anymore then anyone else. Japan was in their shoes once and Japan has surpassed the United States.
United States Manufacturing isn't really in any position to be judging the quality of other countries anymore.
12/23/2009 11:23 AM
GA,
I have seen the quality improve from China the last 20 years. And with in the next 20 years it should equal or surpass the US. When on some items they are doing already.
They may have problems with their environment though.
p911
12/23/2009 11:55 AM
They are working on being socially responsible for the environment as well.
They only real issue with outsourcing to China is if the order is wrong, the length of time it takes to send it back and get corrected. It's not like outsourcing locally and having the vendor come pick it up that day and get it back to you tomorrow.
12/23/2009 10:45 PM
OK Yes in quite number of cases chinese products are good. But did they pay any tech fees? Most of the tech is stolen from many countries. I was told that one USA company started manufacturing one product in china. Soon they went out of business because many small industries sprung up manufacturing identical product at half cost.
Look at the condition of labourers also. They have very few facilities as in other countries. That is why china produces cheap.
Software piracy is hadly supervised there.
etc
01/11/2010 10:32 AM
Software piracy is hardly supervised anywhere except in the USA and Europe.
12/30/2009 3:19 AM
GA to you Sir.
Too many people on this site seem to believe that everything out of China is rubbish. The problem is that people in the West want cheap goods, so they import cheap rubbish from China. However if you want good quality goods out of China and are willing to pay for them they are readily available.
I have just spent a wonderful month long holiday in the USA and I was hard pressed to find anything at all in America that was not made in China (or Indonesia) and most of it was very good quality. Seems such a waste to buy things in America and take them back to China with me, but a lot of the stuff is not sold in China, it is purely for export.
Good Answers: 12
12/23/2009 7:27 PM
I would try a company called "short run plastics"....we use them and the quality is good. They do small qty runs as well. Make sure you specify exactly what you want...ie the quality standard required and you should not have a problem.
Register to Reply 21 comments
Anonymous Poster (1); b v rao (2); daffy (1); Janissaries (4); lyn (2); MOBI (1); phoenix911 (6); WWkayaker (4)
