Previous in Forum: Making a Hydrophobic Plastic Device Permanently Hydrophilic   Next in Forum: Joule-Thomson Process
Exhaust Assembly Paste vs. Anti-Seize Paste
12/23/2009 11:19 AM
Hello friends,
Is the exhaust assembly paste (eg. Carplan Fire Putty) any different of a normal anti seize paste ?
Can I use anti seize paste for the exhaust assembly ?
Also what difference it makes to use copper or aluminium based anti seize paste ? One better than the other ? or different applications ?
thank youuuuu
Coming together is a beginning. Keeping together is progress. Working together is success. Henry Ford
Re: Exhaust assembly paste Vs Anti Seize paste
12/23/2009 11:42 AM
Antiseize is usually a stable compound with the predominant feature- lubrication, even when the solvent has evaporated.
The assembly putty- is predominantly a curing compond, (high temperature or anaerobic) purpose is sealing.
Both have entirely different formulation and usage and can not be interchanged.
For the other aspect there is a guide and here from loctite.
The Cu based antiseize is usually not used for SS
Also you have Ni based (preferable for Brass, SS, Ti, Inconel etc) upto 1400oC.
MoS2 are lower temperature - upto 400-500oC.
Good Answers: 19
12/24/2009 9:47 AM
Thanks for the links. I had always thought the CU base antiseive was better due to higher temperature capabilities. I have an old 8 oz can of the AL that I baought a very long time ago that I still use and it works good enough for my limited home requirements.
Your point that comparing assembly putty to anti-seize being an apples to oranges comparison is an excellent post. Good Answer!
12/24/2009 11:57 AM
Thanks . I too had that concept earlie. the Cu based ones looked so nice and had a feeling (psychological- being of different metallic colour) till I was enlightened.
Good Answers: 56
Re: Exhaust Assembly Paste vs. Anti-Seize Paste
12/24/2009 1:07 AM
What kind of anti-seize paste to use on exhaust manifolds ceased to be a concern many decades ago when I discovered that nothing works better than to throw away the steel nuts and substitute brass ones.
Brass ones never seize, never snap or strip a stud and can be used over again when reassembling.
Frankly, I am surprised to read that there are engines out there that still have steel nuts on the steel exhaust manifold studs. Either the engine is an antique or is a newer one that has a history of being worked on by another.
Not sure as frankly, I've been away from that activity for some time and anything is possible.
L.J.
"Both the revolutionary and the creative individual are perpetual juveniles. The revolutionary does not grow up because he cannot grow, while the creative individual cannot grow up because he keeps growing." Eric Hoffer
Good Answers: 37
12/25/2009 10:14 AM
Last I looked, there were still car companies out there (and small engine makers, etc, too!) who use steel because it's cheaper [first cost], and the hell with the customer. My '56 VW Beetle came with copper nuts on the exhaust, so it's hardly a new idea, but seems to be really tough to justify to the beancounters.
" Ignorance and arrogance have more in common than their last four letters. "
12/29/2009 6:34 AM
The obvious criterion is the temperature rating. If the normal anti-sieze paste has the same temperature rating as the exhaust assembly paste (unlikely), then either could be used. If it is less, then use the exhaust assembly paste as it is the better material for the job.
Register to Reply 6 comments
Anonymous Poster (2); Laughing Jaguar (1); PWSlack (1); Ried (1); Ron (1)
You might be interested in: Anti-seize Compounds, Anti-malware Software
