SA 516 Grade 70 (material) were used for fabrication of LPG Horton sphere during 1980-81. It was designed as per BS 5500-1976. Design temperature was defined as (-) 6 to (+) 55 deg C.
At present design temperature requirement is stiplauted as (-) 27 to (+) 55 deg C and the recommended design code for ASTM materials is ASME Sec VIII only. Remaining life assessment was carried out and was found satisfactory.
Whether the same old material can be used for refabrication of storage vessels as per the latest design code i.e. ASME Sec VIII? If yes then please guide us how to proceed? If no then kindly tell the reason?
