Previous in Forum: Weldolet or Pipe To Pipe   Next in Forum: difference between en8 and en19 steel
techinical note
12/24/2009 9:51 PM
2.REMOVE PARTIAL HELICAL FLANGE ON THIS SIDE ONLY . CLEAN-UP DEPTH VARIES FROM .027 TO .047 ③ .
3..150 REF × R.094 REF PROFILE REVOLVED TO CREATE R.047 DIM (4) PLS.
4.DIMENSION TO THEORETICAL CORNERS.
5.SEE DRAWING 2000-1000F.COO FOR THREAD DETAIL . PITCH = .065②.
6.BREAK ALL EXTERNAL EDGES BY TUMBLING.
7.FUNCTIONAL CHECK PART WITH 5.5 HF PLUG (2000-1005-00) TO CONTACT A Φ.214 GAGE PIN.
8.SYMBOL Ο INDICATES INSPECTION LEVEL.
REF PROCEDURE 743001
can anyone explain some or all( if you are willing)of the above technicial conditions on the drawing?
I am not a home work cheater. I am a translator seeking professional help
Good Answers: 94
Re: techinical note
12/25/2009 8:27 AM
It would help to see a picture of the part this refers to.
It sounds like there is a thread like flange on the part which has to be removed in a localised area. After cleaning up this has to be checked by fitting another part (5.5 HF Plug) & a gauge pin.
Re: techinical note
12/25/2009 10:53 PM
This specification looks like some sort of joke that is intended to cater to a favored contractor who will pretend to understand it, whereas no one else will try to touch it with a ten-foot pole.
Who would ever clean anything to a depth between .027 and 0.47?? I think someone is pullng your leg. If there is a rational explanation for this gobbledy-gook, I'd like to hear it. You ought to pull their plug.
Re: techinical note
12/26/2009 11:18 PM
There are foot notes on the cleanup dems. (3) and a note on the thread pitch. (2) You need the Drawing 1000-1000f.coo, the specifications for the 5.5 plug gauge and .214 gage pin. you also need the ref procedure 743001. What is inspection level O? You need to find this out from the customer. Without all this; who knows? What does the part look like and where is it used?
Line 6. indicates the machining isn't too critical as the edges are broken by putting them in a tumbler. Line 4. Dimension to theoretical corners. Project a line from two ajoining faces and where they cross is the point to measure from. It works great on cad but is a laughable ref in the shop.
A good deed not praised holds behind it a thousand deeds yet undone.
Register to Reply 3 comments
Nigh (1); Randouli (1); Tornado (1)
