Previous in Forum: Earth pit improvement   Next in Forum: regarding the LT capacitor charging
Data Center Integration Solution
12/25/2009 2:05 AM
We are going to setup Data Center , We need solution and suggestion as follows:
1. Building managemnet Systems which is integrate with
- Automatic Lighting Control Systems (with Occupancy PIR Motion Detector)
- CRAC Units (Cooling Systems)
- Environmental Monitoring (Temperature, Humidity, Water Detection, Vibration )
- Mains Power Monitoring (Power, Volt, Ampere , Frequency etc)
- EVery Rack Power Will be shows in BMS ( Intelengent PDU)
-IP CCTV (Integrate with BMS)
-Access Control Systems (Biomatric , Antitheft , RFID )
- Genset Alarm notification
-UPS monitoring in BMS (with Batteries)
- BMS will be alarm notification by Email (SNMP) and SMS (GSM)
-Remote monitoring system ( DRS)
If any one help me , is it possible to integrate the above funtion in our Data Center? We will want also to monitor DRS.
I will be happy anobody communicate with me directly (gurababd@gmail.com)
Merry Chissmass
Evelindev
Re: Data Center Integration Solution
12/25/2009 5:07 PM
Surely you jest.
Search GlobalSpec
Reply to Forum Thread
