Previous in Forum: Jeep Automatic Transmission Problem   Next in Forum: 1988 Ford Ranger Won't Start
fluid drive
12/26/2009 3:42 AM
whats the principle behind fluid drive mechanism?
Re: fluid drive
12/26/2009 7:21 AM
Are you talking about this? http://en.wikipedia.org/wiki/Fluid_Drive
Humm... suspicious you are...
Re: fluid drive
01/03/2010 7:54 PM
Fluid Drive, if you mean What Chrysler had in their 1948-50 Plymouth/Dodge/Chryslers. They had a clutch like a standard, but was only required to get the vehicle moving at a speed ussually for 1st gear, at this point a fluid coupler would have enough oil pressure to cause the automatic transmission system to shift to 2nd gear & 3rd gear. So The Clutch was only used for Changing Directions, as in Reverse &/or starting out from standstill. It was basicly a low pressure automatic, with clutch assist.
