Previous in Forum: Turbine and Idle speed   Next in Forum: CFM
11 comments
Reverse modelling of 3D objects
12/26/2009 4:57 AM
Dear all,
i am having some irregular shape objects and i want to create 3d model for analysis purposes. please suggest if it is possible to have a facitlity to create a 3 D model from an existing object?
Re: Reverse modelling of 3D objects
12/26/2009 5:16 AM
I'm sure that if you sat down in a quiet place and contemplated the question by yourself, you could arrive at the obvious answer to this conundrum all by your lonesome!
12/26/2009 7:16 AM
Although I agree with Lynlynch, I feel tempted to light some more in your search in the darkness... but not that much, of course. You are looking for a model right? So it will never be the real thing, but must be capable of giving you some serious results that are able to predict the reality. So, you need a good approximation to the real thing. Two methods have just arise in my mind while I\m typing. 1- It could be made of simpler solids to get close to the big one you need. 2- It could be made from the external surfaces in, as you mentioned you are thinking about building the model in a facility. You could call it 3D scanning of the surface. Use a good 3D measuring machine, for example, to create a (big) set of points and surfaces as long as you have patience and time to do so and then import it to your modeling software. I'm sure you are using a good one that can handle it. I'm pretty sure you will be able to go on now.
Humm... suspicious you are...
Good Answers: 918
12/26/2009 11:34 AM
Yes, the easiest way is to laser scan the object. Generally, the output of the scan produces a 3D file (i.e., IGES) that can be opened by a 3D CAD software package such as Solidworks, Autocad, etc.
You can buy a tool to scan this yourself, but it is cheaper and better to contract a company that specializes in this service. We have done this many times with very complex parts and the results have been very favorable.
12/26/2009 11:31 PM
You can do a 3D scan and get a point cloud and turn this into a solid model - I have done this for spine models of humans - but it is expensive.
12/26/2009 11:49 PM
This sounds a bit like something I have been wondering about--making a replacement part for something like a vehicle, a part for which no drawing or tooling exists.
Apparently there are digitizers that can produce the multitude of points needed for a 3D drawing/model. Software then cuts the model into very thin slices, after which it can be made layer by layer in a machine that deposits one layer, then the "stage" is lowered the thickness of one layer (just a tiny bit), and the next layer deposited. I think this process is called stereolithography.
I know they can do this in plastic which can then be used for casting, but I am wondering about metal, which I think is now possible, but answers have not been forthcoming very easily.
Lehman57
Good Answers: 918
12/27/2009 8:46 AM
The 3D model, once captured in CAD, can be exported to a CNC machine where it can be machined directly. Solidworks and Mastercam work together this way and this is how we do complex flight grips for aircraft.
12/27/2009 4:32 AM
Do you have access to the originals to scan them?
United States - Member - US Navy Veteran
Location: Nothing sucks more than that moment during an argument when you realize you're wrong.
Good Answers: 22
12/27/2009 9:08 AM
You need to reverse engineer the object. No problem.
Examples:
http://www.gks.com/
http://www.3dscanco.com/services/reverse-engineering.cfm
Google search: reverse engineering services
You never know when it will strike, but there comes a moment when you know that you just aren't going to do anything productive for the rest of the day.
12/27/2009 9:27 AM
Check out www.nextengine.com. They sell a low cost 3d laser scanner that works with solidworks.
12/27/2009 10:20 AM
If you need to scan in 3D and need to be able to do it at very low cost, then I can only recommend this website:-
DIY laserscanner
If you possess a CNC Router table, this might also be of interest for you:-
3d scanner 4 router
Tell us what you think......
12/30/2009 3:13 PM
Register to Reply 11 comments
Andy Germany (2); Anonymous Hero (2); Anonymous Poster (1); bhrescobar (1); Frank12 (1); Lehman57 (1); lyn (1); markar (1); Randall (1)
