Previous in Forum: Air Compressors Catch on Fire   Next in Forum: C-Clamp Question
Calculations for a Twin-Lobe Blower
01/18/2007 6:49 AM
i would like to know the calculations/equations , towards BHP & IHP for a twin-lobe blower .
My application was diffused aeration, for water treatment
Pathfinder Tags: blower twin lobe
Re: Calculations for a Twin-Lobe Blower
01/18/2007 8:04 PM
revolutions per minute and volume of rotary lobe blower equals volume. this simplified but blower manufactures have volume calculations for every frame size.
01/19/2007 3:56 AM
Performance curves published by blower manufacturers can indicate this relationship.
Good Answers: 137
01/19/2007 8:06 AM
Formula for IHP is P1*Q1*((P2/P1)n)-1)/n where P1 and P2 are inlet and outlet absolute pressures, Q1 = actual inlet flow, n = polytropic exponent, usual figure 0.23.
Shaft power (BHP) is IHP/η where η = compressor efficiency. For this sort of blower efficiency usually 60 - 65%, depending on size.
Power in watt if SI units used. I usually put pressures in kPa, then power in kW if flow in m3/s. I assume watt/kW is OK, and ref to HP is for historic reasons. If not you need to convert or work in FPS units, and divide by 550.
Register to Reply 3 comments
Codemaster (1); mtararat (1); PWSlack (1)
