Previous in Forum: Magnetic Power   Next in Forum: Why Are HV Cables Unearthed?
Arc Flash Suits
12/28/2009 3:18 PM
When do you use Arc Flash suits?
Good Answers: 804
Re: Arc Flash Suits
12/28/2009 3:59 PM
Assuming you are in the US:
Where there is an identified risk of exposure to arc flashes in electrical equipment in accordance with NFPA70E. Generally, an "arc flash suit" is appropriate for areas defined as needing "HRC Level 4 PPE " protection. HRC stands for Hazard Risk Category based upon the Calories/Sq. cm of available energy present and PPE stands for Personal Protective Equipment ranging from 0 to 4, with 4 being the highest level of protection required. But that is not gospel, PPE Level 3 can also be interpreted as a "suit". Do your homework and search out "NFPA 70E PPE levels" to read all about it.
If you are not in the US, I can't help.
Re: Arc Flash Suits
12/28/2009 4:02 PM
When there is a danger of arc flash.
Re: Arc Flash Suits
12/29/2009 12:01 AM
In case of a fault in panel or switching.
BNDas
Re: Arc Flash Suits
12/28/2009 6:08 PM
Re: Arc Flash Suits
12/28/2009 6:13 PM
Are you mocking me?
biswanath.das (1); JRaef (1); Mikerho (2); wareagle (1)
