Previous in Forum: Ultrasonic Test (UT) and Die Penetrant Test (DPT)   Next in Forum: Pipe Questions
Calculating Bearing Stress on a Bolted Web
12/29/2009 7:12 AM
A 1" diameter bolt passes through a 1/4" thick web. If a shear load on the bolt is 1.5 Tons, what is the bearing load on the hole in the web? I would appreciate a noddy guide breakdown as I am new at this.
Re: How do I work out Bearing Stress on a bolted web
12/29/2009 7:54 AM
Homework?
12/29/2009 8:08 AM
Yes Final question; can you help?
12/29/2009 10:00 AM
OOPS!
Honesty is the best policy. I admire you freely offering the truth on the question... however, if we do your homework and you get the grade... that just isn't an admirable thing to ask of us.
From the CR4 FAQ:
  • Do your own homework. CR4 is not a homework cheat site. While some here might relish the opportunity to sharpen up old rusty skills by working the homework problem, consider this and consider it well. If you cheat on your homework by using someone else's answers, you are only cheating yourself, because the purpose of any homework or other college assignments is to help you learn - by practice, repetition, and self-discovery. (thanks STL Engineer)
Register to Reply 3 comments
Doorman (1); Jonathan996 (1); lyn (1)
