Previous in Forum: MCC Panels and Chillers   Next in Forum: Calculating Interrupt Cycles
Induction Generator
12/29/2009 8:27 AM
Dear Sir, I am going to take a trial to generate power from Induction Generator by micro hydro turbine. Data Are as below: Induction motor details: 2.2 KW / 900 rpm connected in DELTA with 50 mfd + 100 mfd capacitor connected between RY & RB respectively Head : 13 m Flow : 15-18 liter/sec I just wanted to know that what is the maximum safe speed speed on which this induction generator can work? i.e. For any induction generator what is the safe and maximum speed on which it can be run to generate the electrical power ?
Thanks
Re: Induction Generator
12/30/2009 12:03 AM
Such a system cannot generate any electricity.
However, you may see this:
http://www.qsl.net/ns8o/Induction_Generator.html
bioramani
01/01/2010 9:47 AM
Dear Mr. bioramani, Today I have taken a sucessful trial of induction generator with 2.2 KW/930 rpm motor & 50 mfd capacitor. The system has generated 143 V @ 970 rpm ,44.5 Hz, 2.6 A, 370 Watt Still I require further guidance/experiment to increase the voltage upto 210 V with load
Thanks
12/30/2009 5:19 AM
Have a look @ microhydro.com forum & microhydropower.net
Post the question also there
Frogg
Register to Reply 3 comments
Anonymous Poster (1); bioramani (1); dhanesh.koshti (1)
