Previous in Forum: Reconditioning Cutters   Next in Forum: How to Stick Weld 410 SS to Low Carbon Steel
Welding Filler Wire and 7018 Electrode
12/29/2009 9:10 AM
can any one tell me wht is the meaning of 7018 electrode means what 7 stands for, 0 n so on..n to weld ss 316L to ss 316L thickness 8mm plate which filler wire shld be used..in mig welding
what v do is what v are..mechanical engineers
Re: welding
12/29/2009 9:13 AM
Look the catalog of electrodo manufacturer...
Re: Welding Filler Wire and 7018 Electrode
12/29/2009 9:47 AM
  • The letter E indicates an electrode.
  • The first two digits represent the resulting weld's minimum tensile strength, measured in pounds per square inch (PSI). For example, the number 70 in a E7018 electrode indicates that the electrode will produce a weld bead with a minimum tensile strength of 70,000 PSI.
  • The third digit represents the welding positions for which the electrode can be used. For example, 1 means the electrode can be used in all positions and 2 means it can be used on flat and horizontal.
  • The fourth digit represents the coating type and the type of welding current (AC, DC, or both) that can be used with the electrode.
  • This is not suitable for corrosion resistant steels. Google: "welding SS" and read!
12/30/2009 2:41 AM
Use same material wire 316L or 309L. You can weld with E 7018 if you approve a WPS / PQR .
Register to Reply 3 comments
alfonsoqf (1); Anonymous Poster (1); lyn (1)
