Previous in Forum: High-Power, Low-Weight Lithium Battery   Next in Forum: Grounding Systems and Transient States
8 comments
High/Low Temp LED Display
01/19/2007 3:11 PM
looking for a source that has just the LED Display units that will work in a thermal cycle chamber cycling temps between -40degC to 80degC
Out Of The Inner Circle
Re: High/Low Temp LED Display
01/19/2007 4:02 PM
? You mean just the display to connect to your chamber's thermocouple? Or the whole thermocouple / display thing? If it's the former, your temp cycle manufacturer should have something. If it's the later, get a meter from Fluke, or someone similar.
Good Answers: 27
01/20/2007 11:25 AM
As an addendum to bhankiii, you might also check out Omega Engineering (omega.com). Good source for everything you need from the t/cs outward.
01/20/2007 12:16 PM
My company builds custom temp cycling chambers and thermal platforms. We build our own proprietary display units but also incorporate OEM controllers from outside vendors.
I am not sure if you want a complete controller but if you do here is one source we use : http://www.love-controls.com/index.htm .
These units work with RTD's and thermocouples and have DC voltage & current I/O. There are models with TTL I/O as well.
They are reasonably priced, versatile and reliable.
rega451
01/21/2007 12:42 PM
I see that I was not understand clearly, tho thanks for the feedback.
The LED's will be in the chamber on a test jug, the tech from time to time will be viewing through the glass on the door for error codes these LED will display about equip also in chamber. This has to be this way, and the setup that was in use is having problems with these double stack 8 digit Display going bad now. I was looking for a better replacement for temp range -40degC to +80degC
Thanks
e-mail
hshipley@wabtec.com
01/22/2007 12:43 PM
If you are just looking for the displays themselves, I would recommend Avago Technologies...http://www.avagotech.com/products/parametric-search.jsp?navId=H0,C1,C5231,C4941,C4963,C5094,C5148
The displays are rated to 85C, but will work well up to 105C. The higher temps just accelerate the deterioration of intensity over time.
01/22/2007 9:50 PM
thanks, I can derate the forward current for above max temp, that should increase the life
United States - US - Statue of Liberty - New Member
07/20/2008 4:24 AM
HOW TO MAKE LED SCREEN THAT IS LOW TEMP. ?
AND WHT IS THE TEMP. ?
THIS IS IMPORTANT TO ME
www.elecosn-led-display-screen.com
10/16/2010 10:13 PM
JUST GO FOR A DTC METER FROM SELECTRON MAKE .. U HAVE A ON OFF RELAY CIRUIT TO CONTROL UR WHOLE FUNCTION.
Register to Reply 8 comments
Anonymous Poster (4); bhankiii (1); Bluestone (1); ELECOSN (1); Rega451 (1)
