Previous in Forum: fire figthing calculation   Next in Forum: Mean metal temperature Of Heat Exchanger
9 comments
Finding Natural Gas Velocity
01/02/2010 3:16 AM
Dear all,
Request a simple answer for how to calculate velocity for natural gas in 2" inch SS316L pipe with 3164 kg/hr flow, inlet pr. of 30 barg & exit pressure of 24 barg, with route lenght of nearly 30 mtrs.?
Good Answers: 18
Re: Finding Natural Gas Velocity
01/02/2010 6:24 AM
Dear s-y,
The answer is too high! You should increase the pipe diameter and save yourself a lot of DP.
Massey.
If it ain't broke,leave it well alone .........until it comes looking for you!
01/02/2010 8:31 AM
Thanks for the reply, but i would like to know the formule used for calculating the natural gas velocity in pipes. Can you please post the calculation?
Good Answers: 18
01/02/2010 8:45 AM
Hi s-y,
You could try the following website: www.pipeflowcalculations.com/download.htm
Regards,
Massey.
Good Answers: 213
01/02/2010 10:39 PM
You need the temperature, also...
01/03/2010 8:17 AM
To calculate velocity:
Volumetric flow rate= mass flow rate (3164 kg/hr) / density of the fluid.
Calculate the inter diameter of the pipe and then calculate the internal area of the pipe.
velocity of the fluid inside the pipe is = volumetric flow rate / inside area
Thank You.
01/03/2010 10:33 AM
Dear all.
Thanks a ton for replies, but i just have a query that should we not consider the compressibity factors & the friction co-effcients also during our calculation in the velocity check? Should we not engage the darcy-weisbach equation or the roenard equation for the same?
01/03/2010 11:12 AM
Dear All,
I want to find out velocity of Natural Gas Flowing in a pipeline of distance around 30.0 meters, with flow rates ranging from 2584 kg/hr to 3164 kg/hr, inlet pressures of 30 kg/cm2(g) & exit pressures from the PCV'S 24 kg/cm2(g), with bends in pipe of around 6 nos. I am trying to minimize the number of bends further.. I need this info as soon as possible as i need to purchase the pipes. i am confused of whether to buy 2 inch pipe or 3 inch pipe...Request you all to please answer and help me!!! interms of velocity & pressure drops?
01/03/2010 11:15 AM
since Q=AxV
where A=Cross section area of the pipe
V=Velocity
Q=volumetric flow rate
find now.
01/04/2010 3:44 AM
The Weisbach-Darcy generalised pipe flow equation can be used.
A pressure drop of 0.2barg per metre is far too high.
Register to Reply 9 comments
Anonymous Poster (1); cwarner7_11 (1); Massey 726 (2); PWSlack (1); sarkar.jay.2010 (1); sunil yeluri (3)
