Previous in Forum: how to read electrical schematics   Next in Forum: Rewiring 2 120V legs to one 240V leg for oven elements
DC Motor power required
01/02/2010 4:30 AM
I have a 0.8 tone car ac with drive shaft speed is 1500rpm i want drive it with a DC motor then how much power required for that DC motor.
Re: DC Motor power required
01/02/2010 1:10 PM
About 1/2 - 1 hp depending upon the total system efficiency.
01/03/2010 8:12 PM
I generally assume that using vapour compression cycle air conditioning or refrigeration one can get cooling capacity (Pc) of about 2.5 times as much as electrical power input (Pe). A quick look at two split units installed here at home gives Pc/Pe ratio of 6 kW/2.83 kW=2.12 and 6.76 kW/2.45 kW=2.75. I suspect large difference in two values may be in part as result of using different rating conditions i.e. indoor and outdoor conditions at which rating test is conducted. Admittedly a small amount of that electricity is used to turn indoor and outdoor fans. Your requirement is for Pc= 0.8x3.5 kW=2.8 kW cooling capacity. [1 ton equals approximately 3.5 kW]. Assuming you have a fairly efficient system and minimal transmission losses (belt drive or similar) I would think that you would be safe opting for something in excess of 2.8 kW/2.5=1.12 kW or 1.5 hp. Increasing motor capacity would also reduce risk of motor not being able to start turning compressor. Hope this helps. WR
01/04/2010 11:59 PM
What's the rating of the ac motor? What type of motor? Whats the starting method?Give more info on the existing drive..
R T F M .......
Register to Reply 3 comments
Aldego (1); tcmtech (1); White Rock (1)
