Previous in Forum: invisible shield   Next in Forum: Alternative Formation of Nitronium Ions
Fluid Stiffening Effects
01/04/2010 1:31 AM
For multistage pumps, fluid stiffening effects shall be considered and calculations shall be performed at both one and two times the nominal design clearances. The fluid stiffness of product-lubricated bearings and bearing bushings shall be calculated at both one and two times the nominal design clearances.&
can somebody pls enlighten me ?
I am not a home work cheater. I am a translator seeking professional help
Good Answers: 58
Re: what is "fluid stiffening effects"?
01/04/2010 2:02 AM
In simple terms, the interstage bushings (in particular) and the wear rings etc of a multistage pump act in a manner somewhat similar to lubricated bearings. The pumped fluid present in these relatively close tolerance areas has a stiffening effect on the shaft. (The fluid in the gaps dampens movement).
The larger the clearances the less effective is this dampening effect (fluid stiffening of the system), so API 610 requires that this effect be adequate at both normal and 2x normal clearances.
