Previous in Forum: Grounding Systems and Transient States   Next in Forum: Underwater Speed Measurment
4 Bit Adder/Subtractor Circuits
01/20/2007 11:47 AM
Hiya,
I have been given the task of designing and reporting on a adder/subtractor circuit.
I know and understand the diffrent types of adders, but im at a loss when it comes to the subtracting part.
Can anyone explain how this is accumplished (without giving away too much as it is a university project)
I only need to know the very basics.
Thanks
Lach
Re: 4 Bit Adder/Subtractor Circuits
01/20/2007 3:29 PM
Hello Lach
A binary add i relaitve simle. 1+0=1 and 1+1=0 + carry = 10. You add bit by bit for the result.
A binary sub is an add with the minus signed value inverted +1. I.e. if you will sub 12 - 7 (= 5). Binary it is 1100 - 0111. Invert 0111 to 1000 and add 1, it will bee 1001. Add 1100 and 1001, result 10101. Drop the carry to 0101.
In hardware you put an exor-gate before the B-inputs on the adder circuit. This can be "programmed" as a non inverter for addition and an inverter for subtraction. Adding the LSB 1 can be done to the adding result.
Anders
01/20/2007 7:55 PM
Binary subtraction is just two's compliment addition. Take the number you want to subtract, invert it and add one to it - that's the two's compliment. Now add this value to the number you want to subtract from, and you're done.
Register to Reply 2 comments
