Previous in Forum: Pipe Bending Machine Design   Next in Forum: Pipe Wall Thickness
Wall Thickness for 8"-300# Rating
01/04/2010 10:22 PM
wall thk determination.
what is wall thk for 8"-300# rating?
Re: wall thk determination
01/05/2010 3:15 AM
Good Answers: 61
01/05/2010 1:22 PM
The question:
What is the wall thickness for 8"-300# rating?
My answer:
Functionally if you are the "Piping Material Engineer (PME) developing the Piping Line Class Specifications than you would need to consider all of the following and more:
· The commodity (water, steam, oil, sulfuric acid, etc)
· The fluid state (gas, liquid, slurry)
· The pressure (Design & Operating)
· The temperature (Design & Operating)
· Corrosion allowance
· The expected design life of the plant
· The material (aluminum, carbon steel, stainless steel, 9 chrome, etc.)
· The applicable Code
Please note, the flange rating (Class 300) has nothing to do with the required pipe-wall thickness.
Do it once and do it right
01/05/2010 9:31 PM
Thanks for the reply mr. PennPiper,
basically if we want to give an example refers to std reference about the wall thk, say...150# spec, service is fluid, material is CS...what is the wall thk refers to?
STD WT/ sch.40 or we can say sch.80 or higher...just for quick reference to someone from IE or CS asking for the pipe WT.
Re: Wall Thickness for 8"-300# Rating
01/05/2010 5:58 PM
Anonymous Poster (2); Lahane82 (1); PennPiper (1)
