Previous in Forum: Cooling Tower Efficiency   Next in Forum: Design Pressure and Surge Pressure
Die Electric Section for Submersible Pump
01/05/2010 3:27 PM
I have to install die electric section between the deep water well submersible pump and the column pipes , this is required to prevent electrolysis .
Do you have any information about this piece , and picture , and data that can help ???
Re: Die Electric Section for Submersible Pump
01/06/2010 12:20 AM
The word is dielectric (one word, no space, only one 'e' between 'di' and 'lectric'), meaning insulator. Plastic!
01/06/2010 3:43 AM
Anything non-conductive would do. Just make sure the different metals that it is separating are not electrically connected in any way.
Good Answers: 117
05/14/2010 2:44 AM
even if you install this plastic piece, you will not prevent electrolysis. Try using a sacrificial anode at the bottom of the motor and chemical injection from the surface to the bottom of the motor to be mixed and carried by the produced fluid to surface. Yes I can send you photos of sever damage caused by electrolysis, send me you email.
brich (1); dkwarner (1); PWSlack (1)
You might be interested in: Submersible Pumps, Submersible Mixers
