Previous in Forum: Heil UA   Next in Forum: Corten steel
Multiphase Pump Application
01/06/2010 2:32 AM
How much sense will it make to specify a multiphase pump for crude oil with GOR of 20
and a paltry flow rate of 4000 Bbl/day?
Chuck Cowlagi
Re: multiphase pump application
01/06/2010 3:33 AM
Not much until the required pressure increase is specified.
01/06/2010 5:18 AM
Suction pr = 6 bar
Discharge pr = 18 bar
Proposed to be installed near a well manifold for feeding a separator.
From separator - oil will be flow to an SBM for tanker loading application.Gas flared!
Regards
Chuck Cowlagi
01/06/2010 8:47 AM
What voltage motor (hint: shaft work requirements exceed 106kW)?
01/07/2010 3:38 AM
Supply Voltage 415 V
Frequency : 50 Hz
Phase : 3
The idea of asking the basic question was to see if someone from oilfield experience
would analyse the suitability from the bubble point pressure angle and the wisdom
boosting the pressure just to reach the separator pressure + line losses which are minimal in this case.
Chuck Cowlagi
minimal in the
You might be interested in: Chuck Jaws, Vacuum Greases and Vacuum Pump Oils
