Previous in Forum: Tucker car   Next in Forum: Diesel CAD drawings
16 comments
1991 Isuzu PU Fuel delivery question
01/06/2010 5:56 PM
OK I am stumped on how the fuel pump on this truck works. The pump only works with the key in the crank possion. The pump is in the tank. I hear the pump work when the key is turned. The Question is, does the pump just pressiorise the tank and when the fuel gets up to the front Vacume takes over? I took the fuel line off and turned the key but No fuel sprayed out like a manual pump.
Re: 1991 Isuzu PU Fuel delivery question
01/06/2010 6:29 PM
"The pump only works with the key in the crank possion." If this were true, you wouldn't be able to hear the fuel pump because the engine would be cranking.
"I hear the pump work when the key is turned." Turned to the on position, not the crank position.
The pump runs just long enough to charge the fuel line to the proper pressure.
It starts up again soon when the engine starts, but you can't hear it then.
" I took the fuel line off and turned the key but No fuel sprayed out like a manual pump." Where did you take the fuel line off?.
01/06/2010 10:33 PM
possion is actually spelled position.
pressiorise is actually spelled pressurize.
Vacume is actually spelled vacuum (not capitalized as it is not the first word in the sentence).
Your punctuation and grammar are passable otherwise.
Good Answers: 123
Re: Proof reading "Guest"
01/06/2010 11:43 PM
Are you Mrs. Clark? I had you as an English teacher way back in the 1960s. You were an annoying old hag then. Wow, you must be about 130 years old now. Did you ever find any companionship? You always seemed to have no thing to do in your life but be a pain in the butt to all of the students, and faculty. If so, you seem to still be obsessed with spelling and punctuation errors. do you still go to the Gulf gas station in Forest Hills on Sunday evenings. It was just great hearing from you again.
Bob
01/07/2010 12:19 AM
That's funny!
01/07/2010 12:20 AM
Bobby, Bobby! It's great to hear from you, aside from the manner in which you're speaking to me. I see you left me a number of errors in your post which, though I would like to, I will not point out to you and leave it as an exercise to correct yourself. Your assignment is due tomorrow by 8:00 AM Estern Standard Time.
Cheers!
By the way, if I was Mrs. Clark back then, why were you asking me if I had found companionship? My husband is (of course) Herbert Clark; he teaches Social Studies here at Lincoln Elementary School. You must work harder to successfully communicate!
Remember - tomorrow by 8:00 AM Estern Standard Time!
Mrs. Clark
Good Answers: 123
01/06/2010 11:46 PM
In some of the GM designed fuel systems, the in tank fuel pump is run a 1-3 seconds when the key is first turned to the run position. Then the pump will be powered in the start position. Once the engine starts, the oil pressure switch will supply power to the fuel pump as long as the oil pressure is above 8 PSI roughly. Good luck.
Bob
01/06/2010 11:55 PM
Look I am Not A english professor I just want to know how the Fuel pump works on a 1991 Isuzu pu. I don't want no smart ass responces if you can't answer my question keep your opionion to your self.
Good Answers: 123
01/07/2010 12:19 AM
Please continue reading the responses. My answer was in response to Mrs. Clark's reply to Llynch's well worded answer. Good luck in your search for answers. If you have a test light, we will walk you through your problem.
Bob
Good Answers: 137
01/07/2010 5:03 AM
I think we need more information first.
Is there actually a problem with the vehicle or is the question just from curiosity?
Diesel or petrol (oh, all right, gas)? If gas, is it injection or carb?
I've not heard of pressurising the tank, or of a vacuum system, to deliver fuel. I believe tanks are pressurised in some vehicles (or at least only vented at an elevated pressure) presumably to reduce evaporation loss, not to move the fuel.
BTW - Mrs. Clark - shouldn't it be Eastern Standard Time?
Cheers........Codey
01/07/2010 12:49 PM
OK the truck is fuel injected. The guy I baught it from said the problem was the truck was hard to start and if it did start it would spit and sputter like starving for fuel. I put gas in it,charged the buttery and tried to start it,Nothing. I took the air cleaner off and sprayed starting fuel in the air duct and it would run as long as you kept spraing fluid. A couple times it backfired(maybe timing) but can't get it to run to check the timing. So I started looking at the fuel delivery. I took the line off where it comes up from the back into a small diofram looking thing before going to the fuel rail. I cranked the motor over but got NO fuel to come out. So I started checking the fuel pump. A new one was said to be put on. the pump only works in the crank passion and as soon as you release the key it stops working. I then went to the back where the tank is. had a friend turn the key to the on possession(nothing) then to the crank possession(pump started pumping) I then took the fuel line off going to the filter bolted to the frame. first on the side from the tank. Fuel came poring out. then went to other side of filter fuel came out but not as strong of a stream. I then went to the front and took the line off where the diofram looking thing is. Cranked the engine NO fuel came out. the line is clear, was blown out with a air compressor, there is fuel in the line it slowly drips out But Nothing when you crank the motor. I AM STUMPED
Good Answers: 123
01/07/2010 1:44 PM
The first thing you should do is replace the fuel filter in the frame area. You already know the thing is restrictive.
While you are at the auto parts store, invest in a repair manual for your truck. There should be soft cover books for around $15.00. Try to follow the 12 volt power supply that feeds the fuel pump. Trace the path that takes the power from the pump back towards the front of the truck. We already know that part of the supply is the starter switch. Besides that there must be a power supply that is live when the key is in the run position.
If you want to test, use a temporary power supply to the wire that powers the pump to see if the truck will run at all.
Good luck, and replace that filter before you get too deep into this.
Bob
01/07/2010 5:27 PM
bob_c is absolutely correct about the manual... Chilton, Haynes, Peterson (I think) to name some, they are all about the same. The $15-20 bucks you spend now will save you many troubles in the future.
p.s.: I had a '86 Dodge pickup for 22 years, I had and used three different manuals. While each is in itself informative, one book would more thoroughly detail brake and drivetrain problems, another more info about electrical and 4WD... you get the idea. Those books helped me get more than 400,000 Mi out of a 318 Mopar.
(Had to spell-check, not wishing to be dunned by Mrs. Carkl...)
01/07/2010 11:29 PM
I think Bob C has found the proble,. When the oil pressure switch fails the fuel pump only works when cranking, sometimes it will last longer as there is also a delay switch on the cut off. Try shorting the oil pressure switch terminals with the ignition on and see if the pump works.
I am a bit worried you are checking the fuel drain line from the pressure regulator (diaphram thingy) not the feed line to the fuel rail which should come straight from the filter into the rail. That would explain your abscence of fuel!
Finally try jumping the pump with a line straight from the battery and check the pumps earth wire for bad connection.
01/08/2010 6:51 PM
You can always run temporary power from the battery for the fuel pump. Most of the time they will start with a can of starting fluid. Check for spark first if you have good spark try some starting fluid.
http://www.alldata.com/ They sell a years service for around $29.95 they have good wiring diagrams.
01/08/2010 11:43 PM
While I haven't worked on an Isuzu in years, most of the GM vehicles fuel systems work off the ECM/PCM. You'll have a fuel "prime" circuit and you'll have a "run" circuit. The prime works for about 30 seconds to prime the system if you just cycle the key to the on position. When you cycle the key to crank, the "run" circuit takes over for the duration of the run cycle. The mention of the fuel restriction after the filter is the first thing you need to address as others have said.
Another thing I would check would be the coolant temp sensor as they play a big part in fuel delivery.
01/09/2010 2:22 PM
Thank you all for your responses. The project is temporally on hold dew to the cold weather. I will check every thing you all have suggested when the weather worms up Again thank you all.
Register to Reply 16 comments
Anonymous Poster (3); bob c (4); Codemaster (1); Doorman (1); longbow243 (1); lyn (1); Mikerho (1); rhandwor (1); Tledoux (3)
You might be interested in: Fuel Cells, Fuel Testers
