Previous in Forum: Over current device   Next in Forum: iso later quarries
insulating matarial
01/07/2010 5:18 AM
what is the kva rating for insulator
Re: insulating matarial
01/07/2010 5:31 AM
An insulator would not have a kva rating, but it would quite likely have a kv rating. It is withstanding voltage, not volts and amps both.
Good Answers: 29
01/07/2010 8:27 AM
There are many types of insulators out there used for different jobs. Bone up a little here and try to be more specific and maybe we can answer or direct you to a source.
You are invited to vote on the global sysops proposal.
Click here for more information.
Hide]
[Help us with translations!]
Insulator (electrical)
From Wikipedia, the free encyclopedia (Redirected from Electrical insulation) Jump to: navigation, search
This article is
in need of attention from an expert on the subject. WikiProject Physics or the Physics Portal may be able to help recruit one. (November 2008)
Conducting copper wire insulated by an outer layer of polyethylene
An insulator, also called a dielectric, is a material that resists the flow of electric current. An insulating material has atoms with tightly bonded valence electrons. These materials are used in parts of electrical equipment, also called insulators or insulation, intended to support or separate electrical conductors without passing current through themselves. The term is also used more specifically to refer to insulating supports that attach electric power transmission wires to utility poles or pylons.
Some materials such as glass, paper or Teflon are very good electrical insulators. A much larger class of materials, for example rubber-like polymers and most plastics are still "good enough" to insulate electrical wiring and cables even though they may have lower bulk resistivity. These materials can serve as practical and safe insulators for low to moderate voltages (hundreds, or even thousands, of volts).
Contents [hide]
[edit] Physics of conduction in solids
Electrical insulation is the absence of electrical conduction. Electronic band theory (a branch of physics) predicts that a charge will flow whenever there are states available into which the electrons in a material can be excited. This allows them to gain energy and thereby move through the conductor (usually a metal). If no such states are available, the material is an insulator.
Most (though not all, see Mott insulator) insulators are characterized by having a large band gap. This occurs because the "valence" band containing the highest energy electrons is full, and a large energy gap separates this band from the next band above it. There is always some voltage (called the breakdown voltage) that will give the electrons enough energy to be excited into this band. Once this voltage is exceeded, the material ceases being an insulator, and charge will begin to pass through it. However, it is usually accompanied by physical or chemical changes that permanently degrade the material's insulating properties.
Materials that lack electron conduction are insulators if they lack other mobile charges as well. For example, if a liquid or gas contains ions, then the ions can be made to flow as an electric current, and the material is a conductor. Electrolytes and plasmas contain ions and will act as conductors whether or not electron flow is involved.
[edit] Breakdown
Insulators suffer from the phenomenon of electrical breakdown. When the electric field applied across an insulating substance exceeds in any location the threshold breakdown field for that substance, which is proportional to the band gap energy, the insulator suddenly turns into a resistor, sometimes with catastrophic results. During electrical breakdown, any free charge carrier being accelerated by the strong e-field will have enough velocity to knock electrons from (ionize) any atom it strikes. These freed electrons and ions are in turn accelerated and strike other atoms, creating more charge carriers, in a chain reaction. Rapidly the insulator becomes filled with mobile carriers, and its resistance drops to a low level. In air, the outbreak of conductivity is called "corona discharge" or a "spark." Similar breakdown can occur within any insulator, even within the bulk solid of a material. Even a vacuum can suffer a sort of break down, but in this case the breakdown or vacuum arc involves charges ejected from the surface of metal electrodes rather than produced by the vacuum itself.
[edit] Uses
Insulators are commonly used as a flexible coating on electric wire and cable. Since air is an insulator, no other substance is needed to "keep the electricity within the wires." However, wires which touch each other will produce cross connections, short circuits, and fire hazards. In coaxial cable the center conductor must be supported exactly in the middle of the hollow shield in order to prevent EM wave reflections. And any wires which present voltages higher than 60V can cause human shock and electrocution hazards. Insulating coatings prevent all of these problems.
In electronic systems, printed circuit boards are made from epoxy plastic and fiberglass. The nonconductive boards support layers of copper foil conductors. In electronic devices, the tiny and delicate active components are embedded within nonconductive epoxy or phenolic plastics, or within baked glass or ceramic coatings.
In microelectronic components such as transistors and ICs, the silicon material is normally a conductor because of doping, but it can easily be selectively transformed into a good insulator by the application of heat and oxygen. Oxidized silicon is quartz, i.e. silicon dioxide.
In high voltage systems containing transformers and capacitors, liquid insulator oil is the typical method used for preventing sparks. The oil replaces the air in any spaces which must support significant voltage without electrical breakdown. Other methods of insulating high voltage systems are ceramic or glass wire holders and simply placing the wires with a large separation, using the air as insulation.
[edit] Telegraph and power transmission insulators
10 kV ceramic insulator, showing sheds
Suspended wires for electric power transmission are bare, except when connecting to houses, and are insulated by the surrounding air. Insulators are required at the points at which they are supported by utility poles or pylons. Insulators are also required where the wire enters buildings or electrical devices, such as transformers or circuit breakers, to insulate the wire from the case. These hollow insulators with a conductor inside them are called bushings.
[edit] Material
Insulators used for high-voltage power transmission are made from glass, porcelain, or composite polymer materials. Porcelain insulators are made from clay, quartz or alumina and feldspar, and are covered with a smooth glaze to shed water. Insulators made from porcelain rich in alumina are used where high mechanical strength is a criterion. Porcelain has a dielectric strength of about 4–10 kV/mm.[1] Glass has a higher dielectric strength, but it attracts condensation and the thick irregular shapes needed for insulators are difficult to cast without internal strains.[2] Some insulator manufacturers stopped making glass insulators in the late 1960s, switching to ceramic materials.
Recently, some electric utilities have begun converting to polymer composite materials for some types of insulators. These are typically composed of a central rod made of fibre reinforced plastic and an outer weathershed made of silicone rubber or EPDM. Composite insulators are less costly, lighter in weight, and have excellent hydrophobic capability. This combination makes them ideal for service in polluted areas. However, these materials do not yet have the long-term proven service life of glass and porcelain.
[edit] Design High voltage ceramic bushing during manufacture, before glazing.
The electrical breakdown of an insulator due to excessive voltage can occur in one of two ways:
  • Puncture voltage is the voltage across the insulator (when installed in its normal manner) which causes a breakdown and conduction through the interior of the insulator. The heat resulting from the puncture arc usually damages the insulator irreparably.
  • Flashover voltage is the voltage which causes the air around or along the surface of the insulator to break down and conduct, causing a 'flashover' arc along the outside of the insulator. They are usually designed to withstand this without damage.
Most high voltage insulators are designed with a lower flashover voltage than puncture voltage, so they will flashover before they puncture, to avoid damage.
Dirt, pollution, salt, and particularly water on the surface of a high voltage insulator can create a conductive path across it, causing leakage currents and flashovers. The flashover voltage can be more than 50% lower when the insulator is wet. High voltage insulators for outdoor use are shaped to maximize the length of the leakage path along the surface from one end to the other, called the creepage length, to minimize these leakage currents.[3] To accomplish this the surface is molded into a series of corrugations or concentric disk shapes. These usually include one or more sheds; downward facing cup-shaped surfaces that act as umbrellas to ensure that the part of the surface leakage path under the 'cup' stays dry in wet weather. Minimum creepage distances are 20–25 mm/kV, but must be increased in high pollution or airborne sea-salt areas.[4]
[edit] Cap and pin insulators Cap and pin insulator string (the vertical string of discs) on a 275 kV suspension pylon.
Higher voltage transmission lines use modular cap and pin insulator designs (see picture above). The wires are suspended from a 'string' of identical disk-shaped insulators which attach to each other with metal clevis pin or ball and socket links. The advantage of this design is that insulator strings with different breakdown voltages, for use with different line voltages, can be constructed by using different numbers of the basic units. Also, if one of the insulator units in the string breaks, it can be replaced without discarding the entire string. They are constructed of a ceramic or glass disk with a metal cap and pin cemented to opposite sides. In order to make defective units obvious, glass units are designed with Class B construction: an overvoltage causes a puncture arc through the glass. The glass is heat-treated so it will shatter, making the damaged unit visible. However the mechanical strength of the unit is unchanged, so the insulator string will stay together. Standard disk insulator units are 10 inches (25 cm) in diameter and 5+3⁄4 in (15 cm) long, can support a load of 80-120 kN (18-27 klbf), have a dry flashover voltage of about 72 kV, and are rated at an operating voltage of 10-12 kV.[5] However, the flashover voltage of a string is less than the sum of its component disks, because the electric field is not distributed evenly across the string but is strongest at the disk nearest to the conductor, which will flashover first. Metal grading rings are sometimes added around the lowest disk, to reduce the electric field across that disk and improve flashover voltage.
Typical number of disk insulator units for standard line voltages[6]
Line voltage
(kV)
Disks
34.53
464
695
927
1158
1389
16111
19613
23015
28719
34522
36023
A recent photo of an open wire telegraph pole route with traditional porcelain insulators. Quidenham, Norfolk, United Kingdom. [edit] History
The first electrical systems to make use of insulators were telegraph lines; direct attachment of wires to wooden poles was found to give very poor results, especially during damp weather.
The first glass insulators used in large quantities had an unthreaded pinhole. These pieces of glass were positioned on a tapered wooden pin, vertically extending upwards from the pole's crossarm (commonly only two insulators to a pole and maybe one on top of the pole itself). Natural contraction and expansion of the wires tied to these "threadless insulators" resulted in insulators unseating from their pins, requiring manual reseating.
Amongst the first to produce ceramic insulators were companies in the United Kingdom, with Stiff and Doulton using stoneware from the mid 1840s, Joseph Bourne (later renamed Denby) producing them from around 1860 and Bullers from 1868. Utility patent number 48,906 was granted to Louis A. Cauvet on July 25, 1865 for a process to produce insulators with a threaded pinhole. To this day, pin-type insulators still have threaded pinholes.
The invention of suspension-type insulators made high-voltage power transmission possible. Pin-type insulators were unsatisfactory over about 60,000 volts.
A large variety of telephone, telegraph and power insulators have been made; some people collect them.
[edit] Insulation of antennas
Egg shaped strain insulator
Often a broadcasting radio antenna is built as a mast radiator, which means that the entire mast structure is energized with high voltage and must be insulated from the ground. Steatite mountings are used. They have to withstand not only the voltage of the mast radiator to ground, which can reach values up to 400 kV at some antennas, but also the weight of the mast construction and dynamic forces. Arcing horns and lightning arresters are necessary because lightning strikes to the mast are common.
Guy wires supporting antenna masts usually have strain insulators inserted in the cable run, to keep the high voltages on the antenna from short circuiting to ground or creating a shock hazard. Often guy cables have several insulators, placed to break up the cable into lengths that are not submultiples of the transmitting wavelength to avoid unwanted electrical resonances in the guy. These insulators are usually ceramic and cylindrical or egg-shaped (see picture). This construction has the advantage that the ceramic is under compression rather than tension, so it can withstand greater load, and that if the insulator breaks the cable ends will still be linked.
These insulators also have to be equipped with overvoltage protection equipment. For the dimensions of the guy insulation, static charges on guys have to be considered, at high masts these can be much higher than the voltage caused by the transmitter requiring guys divided by insulators in multiple sections on the highest masts. In this case, guys which are grounded at the anchor basements via a coil - or if possible, directly - are the better choice.
Feedlines attaching antennas to radio equipment, particularly twin lead type, often must be kept at a distance from metal structures. The insulated supports used for this purpose are called standoff insulators.
[edit] Insulation in electrical apparatus
The most important insulation material is air. A variety of solid, liquid, and gaseous insulators are also used in electrical apparatus. In smaller transformers, generators, and electric motors, insulation on the wire coils consists of up to four thin layers of polymer varnish film. Film insulated magnet wire permits a manufacturer to obtain the maximum number of turns within the available space. Windings that use thicker conductors are often wrapped with supplemental fiberglass insulating tape. Windings may also be impregnated with insulating varnishes to prevent electrical corona and reduce magnetically induced wire vibration. Large power transformer windings are still mostly insulated with paper, wood, varnish, and mineral oil; although these materials have been used for more than 100 years, they still provide a good balance of economy and adequate performance. Busbars and circuit breakers in switchgear may be insulated with glass-reinforced plastic insulation, treated to have low flame spread and to prevent tracking of current across the material.
In older apparatus made up to the early 1970s, boards made of compressed asbestos may be found; while this is an adequate insulator at power frequencies, handling or repairs to asbestos material will release dangerous fibers into the air and must be carried out with caution. Wire insulated with felted asbestos was used in high-temperature and rugged applications from the 1920s. Wire of this type was sold by General Electric under the trade name "Deltabeston"[7]
Live-front switchboards up to the early part of the 20th century were made of slate or marble.
Some high voltage equipment is designed to operate within a high pressure insulating gas such as sulfur hexafluoride.
Insulation materials that perform well at power and low frequencies may be unsatisfactory at radio frequency, due to heating from excessive dielectric dissipation.
Electrical wires may be insulated with polyethylene, crosslinked polyethylene (either through electron beam processing or chemical crosslinking), PVC, Kapton, rubber-like polymers, oil impregnated paper, Teflon, silicone, or modified ethylene tetrafluoroethylene (ETFE). Larger power cables may use compressed inorganic powder, depending on the application.
Flexible insulating materials such as PVC (polyvinyl chloride) are used to insulate the circuit and prevent human contact with a 'live' wire – one having voltage of 600 volts or less. Alternative materials are likely to become increasingly used due to EU safety and environmental legislation making PVC less economic.
[edit] Class 1 and Class 2 insulation Main article: Appliance classes
All portable or hand-held electrical devices are insulated to protect their user from harmful shock.
Class 1 insulation requires that the metal body and other exposed metal parts of the device is connected to earth via a "grounding" wire which is earthed at the main service panel; but only basic insulation of the conductors is needed. This equipment is easily identified by a third pin on the power plug for the grounding connection.
Class 2 insulation means that the device is double insulated. This is used on some appliances such as electric shavers, hair dryers and portable power tools. Double insulation requires that the devices have both basic and supplementary insulation, each of which is sufficient to prevent electric shock. All internal electrically energized components are totally enclosed within an insulated body that prevents any contact with "live" parts. They can be recognised because their power plugs have two pins, or on three pin plugs the third (earth) pin is made of plastic rather than metal. In the EU, double insulated appliances all are marked with a symbol of two squares, one inside the other.
[edit] See also
Electronics portal
[edit] Notes
  1. ^ Cotton, H. (1958). The Transmission and Distribution of Electrical Energy. London: English Univ. Press. copied on Insulator Usage, A.C. Walker's Insulator Information page
  2. ^ Holtzhausen, J.P.. "High Voltage Insulators". IDC Technologies. http://www.idc-online.com/technical_references/pdfs/electrical_engineering/highvoltage.pdf. Retrieved 2008-10-17.
  3. ^ Grigsby, Leonard L. (2001). The Electric Power Engineering Handbook. USA: CRC Press. ISBN 0849385784. http://books.google.com/books?id=wiv1tuMDbTEC&pg=PT1346&lpg=PT1346&dq=%22utility+transformer%22&source=web&ots=XwZnFMsRK8&sig=68TttGd59rC3_TstnrUd8hvXUHI&hl=en&sa=X&oi=book_result&resnum=5&ct=result#PPT385,M1.
  4. ^ Diesendorf, W. (1974). Insulation Coordination in High Voltage Power Systems. UK: Butterworth & Co.. ISBN 0408704640. reprinted on Overvoltage and flashovers, A. C. Walker's Insulator Information website
  5. ^ Bernhard, Frank (1921). EMF Electrical Year Book. Electrical Trade Pub. Co.. p. 822. http://books.google.com/books?id=pf5MAAAAMAAJ&pg=RA1-PA822&lpg=RA1-PA822&dq=Deltabeston&source=web&ots=Qc-Y6umzIm&sig=j_XZBSlLWY509j3cSwaL1Vv4R74.
[edit] References
[edit] External links
Wikimedia Commons has media related to:
Electric insulator
Retrieved from "http://en.wikipedia.org/wiki/Insulator_(electrical)" Categories: Fundamental physics concepts | Dielectrics | Ceramic engineering Hidden categories: Physics articles needing expert attention | Articles needing expert attention from November 2008 | All articles needing expert attention Views
Personal tools
Navigation
Search Interaction
Toolbox
Languages
01/12/2010 3:32 AM
Most important for a insulator is Basic Insulation impulse level shortly called as BIL Value.That is the apart from the power frequency KV withstand surge with wave form being different can puncture the insulation.This value is much higher than Power frequency voltage withstand value,
nesubra (1); RDGRNR (1); Tornado (1)
