Previous in Forum: underground vessel design   Next in Forum: Oil products removal before reparing
Relation between Fluid velocity and Cavitation in a Pipeline?
01/09/2010 7:52 AM
Hello,
Can any one tell me that what is the relation between Fluid velocity and Cavitation in a Pipeline?
Good Answers: 143
Re: Relation between Fluid velocity and Cavitation in a Pipeline?
01/09/2010 10:49 AM
In the simplest case, the cavitation number varies inversely as the square of the velocity.
Good Answers: 101
01/10/2010 12:27 AM
The higher the fluid velocity, the lower the fluid pressure within the pipe is and the higher the chances of cavitation developing become.
01/14/2010 2:14 PM
Depending on how much education you want you might try to Google "differential pressure measurement" The theory you will find at a few of those sites may answer your question quite well.
Good Answers: 60
03/27/2010 10:17 PM
DVader1000 (1); Maxxx (1); peterg7lyq (1); TVP45 (1)
