Previous in Forum: Oil products removal before reparing   Next in Forum: Where did ASME VIII div1 got its wall thickness theory from?
SA 213 TP 304L
01/09/2010 12:02 PM
If we use SA 213 TP-304 L grade tube up to 520 Degree C Temp for 20 Minute then what type of degradation can take place.
We have one electrical heater having a shell of SA213 TP-304L .That is design for 300 Degree C ONLY but due to some reason electrical heater did not cut off and temp of shell reach up to 520 Degree C. This will remain for 20 Minute and after that heater was switch off.
So pl. mention what type of metallurgical degradation can occur ?
Re: SA 213 TP 304L
01/09/2010 12:29 PM
1. at 500oC+ Cr starts seggregating as Chromium carbide and that reduces the properties on the steel as well as the absence of Chromium is likely to make it more prone to corrosions (sensitizated)
2. Approximately 4750C is the temperature where one encounters temper embrittlement.
Re: SA 213 TP 304L
01/09/2010 2:36 PM
Since it is a 304 series I agree you may observe chromium segregation. This effect may be a problem if the material is submitted several times to the temperature, because this effect also depends on time to occur. The result is that, as mentioned, corrosion may arise from the sensitized areas. You have at your side this SS is low C, so, less prone to chromium carbide formation. Over time you may observe pitting corrosion or corrosion in key areas like joints, welds, etc. But I do not think temper embrittlement will be a problem, once this is austenitic stainless steel.
Humm... suspicious you are...
Re: SA 213 TP 304L
01/09/2010 6:13 PM
That is correct - carbide precipitation (which can lead to detrimental corrosion/mechanical problems) is a function of carbon levels, temperature, and time.
For the low carbon 304L, please see the popular stainless-carbide diagram with the well known "nose" function. And note that it would take just under 10 hours at 600 deg C for the 0.03% carbon "L" grade stainless to start forming the undesirable elements.
http://www.staff.ncl.ac.uk/s.j.bull/mmm373/WELDMAT/img016.gif
So if you don't see any gross mechanical deformations of your heater (and don't continue with this overheating practice) you will be fine.
A final question, is this heater classified as a pressure vessel or is it only at almospheric pressure?
Re: SA 213 TP 304L
01/09/2010 11:41 PM
Sir This heater is designed as a pressure vessel according to ASME Section VIII Div-1 for Design pressure -10 Bar and 300 Degree C.
Good Answers: 18
Re: SA 213 TP 304L
01/10/2010 12:24 PM
By restricting the carbon content to 0.03% maximum, the 304L or 316L, ( any low carbon) type steels are rendered sufficiently immune to carbide precipitation in the sensitising temperature range of 425-8700C. These steels can be welded, stress relieved if required or used without loss of corrosion resistance.
However if the steels remain in these sensitising temperature range for extended period of service, carbide can precipitate in significant quantities to cause intergranular corrosion.
These steels re usually exployed below 4250 C.
Similarly the stabilized steels have sufficient amount of columbium + Tantalum or Titanium in relation to carbon. These steels also exbits higer resistance to corrossive atmosphere in the sensitising tempearature of 425-8700C...
Again, sensitation occurs under certain conditions, under some media, or during service at about 6500C and not all the times.
sridhar
What we have done for ourselves alone dies with us: while what we have done for other and the society remains and is immortal.
Anonymous Poster (3); bhrescobar (1); SRIDHAR (1)
