Greetings to all.
" All sciences are vain and full of errors that are not born of experience, mother of all certainty, and that are not tested by experience..." Leonardo
On that note I need your expert opinions.
I developed a new light gauge open web steel truss design using 18 ga (1.143 mm) galvanized steel (Galvalume), cold roll formed chord and web elements.
I would like help in determining what would be the most cost effective and expedient industrial fastening process to connect the joints of the chord and web elements.
I have considered:
1. Welding such as resistance weld, pulsation weld, flare groove weld fusion, laser as well as spot welding.
2. Mechanical such as screw, self punching rivets, and to a lesser extent, bolts.
The truss fabrication process can be either automated or manual.
On prototype fabrication and testing I have used screw connections successfully, however I would prefer a more expeditious method.
Thank you all in advance for your help.
Vince
