Previous in Forum: Help me remeber what I have forgotten.   Next in Forum: Galvanized Light Gauge Steel Connections
Excel Worksheet Tabs - Format to "dd mmm yy" Macros Built - Missing Format
01/11/2010 11:12 AM
I recently built two macros through the help of friends and google to take and build a Table of Contents - based off of an unlimited number of worksheets within a workbook. A second Macro was built to replace the information from the TOC which inputs in Column A with new information put into Column B - however the information I am inputting into Column B to rename the worksheet tabs are dates - currently formatted as dd mmm yy. When I run the macro it does not return the dates - it will only return a value if I change the format of the column to general - which places to Unicode of the date into the worksheet Tab... I am either missing a formatting string in my macro or question if I have to build another macro to translate the Unicode string into a "dd mmm yy" format. Any assistance would be great. I am creating a new schedule to where the end user only needs to change one date from year to year and all values will update after both macro's are run.
Here are the two macro's built -
Sub CreateTOC()
Dim NumSheets As Integer
'creates Table Of Contents
NumSheets = Sheets.Count
For j = 1 To NumSheets
Worksheets("TOC").Cells(j, 1) = Sheets(j).Name
Next j
End Sub
Sub ChangeSheetNames()
Dim ws As Worksheet
Dim r As Range
Dim s As Range
Set r = Worksheets("TOC").Range("A1", Range("A65536").End(xlUp))
For Each s In r.Cells
For Each ws In ActiveWorkbook.Worksheets
If ws.Name <> "TOC" Then
If ws.Name = s Then
ws.Name = s.Offset(0, 1)
On Error Resume Next 'Will continue if an error results
End If
End If
Next ws
Next s
End Sub
Column A (TOC) = the data extracted from the TOC Macro
Column B (TOC) = the new worksheet tab name assignments currently equal to values set in Column C
Column C (TOC)= dates and formulas - currently C2 equals 3 Jan 10 and C3 equals (C2+7) and so on throughout the column.
Col A Col B Col C
TOCMacro RefChange Formula
4018103 Jan 1003 Jan 10Change this entry only
4018810 Jan 1010 Jan 10
4019517 Jan 1017 Jan 10
4020224 Jan 1024 Jan 10
4020931 Jan 1031 Jan 10
4021607 Feb 1007 Feb 10
4022314 Feb 1014 Feb 10
4023021 Feb 1021 Feb 10
4023728 Feb 1028 Feb 10
thanks for anyones help in resolving my missing link...
- J
Good Answers: 204
Re: Excel Worksheet Tabs - Format to "dd mmm yy" Macros Built - Missing Format
01/12/2010 12:39 AM
What is the purpose of building the table of contents?
There is a method you could use in your first sub that could make those items into active links to jump to the clicked-on item.
I think you are saying you wish for the tab names to contain the dates? and the table of contents to link to them. Where is the date information coming from for the names? Here is a method of creating hyperlinks in excel. Yes you can use hyperlinks to select the other sheets.. its better because they are underlined.
Date information is stored as that number you are finding, but there is an algorithm for converting it to a desired format. Here is a description of the problem.. and potential solution. thought there was a function for it already.. but couldn't find it.. will keep seaching.
Chris
01/12/2010 11:33 AM
Chris,
I am using the TOC essentially as a way of running the Macro's to rename the Sheet Tabs into a list of dates I put into the table. I want to the Macro to create me a list in a TOC in Column A - then take the values in Column A and replace them with the values in Column B - this way I can update a single cell within the TOC created page - and run the Macro to update the calender from year to year or from a date range to a date range...
I have the formatting issue resolved now in the ChangeSheetName () Macro to accept the value of a date in the "dd mmm yy" format. However, the issue I am having now is getting the TOC () Macro to understand that format when it creates a new TOC and then assigned the newly updated values in Column B into the worksheet - it currently will not replace the value in Column A in a Cell Formatted "dd mmm yy" value with the new value in Column B. Hope this makes sense.
Eventually I will link the TOC to the sheet tabs to ease the usage for the end user.
Thanks.
-J
01/12/2010 2:39 AM
While renaming the sheet try using .text
ws.Name = s.Offset(0, 1).text instead of ws.Name = s.Offset(0,1)
Please let me know if it works.
01/12/2010 11:28 AM
The s.Offset(0,1).text addition solved the problem of the format - however I now have an issue in the first Macro with it understanding the format of the newly assigned tabs.
If I re-run Macro: CreateTOC() - it does not pick up the new name of the worksheet tab - another formatting issue somewhere... I tried to use Format(" ", "dd mmm yy") in the programming but it still does not recognize the format... Can you assist.
My big goal is to continue to use this sheet from here on out... changing one cell over to a new date - which updates all worksheets - and executing two Macros to change the names of the Worksheet Tabs with the newly updated information.
I have relisted the Macro below for the TOC () and the ChangeSheetsName()
Sub CreateTOC()
Next j
End Sub
Dim ws As Worksheet
Dim r As Range
Dim s As Range
If ws.Name = s Then
ws.Name = s.Offset(0, 1).Text
End If
End If
Next ws
Next s
End Sub
Thanks for your help.
01/13/2010 1:23 AM
I couldn't really understand the issue you mentioned in your reply.
I tried your code. during the first run, all seems to be normal, but when you run it a second time to collect the sheet names you already created with the macro, it collects the dates but inserts a dash (-) between the numbers (dd-mmm-yy), but you don't want that (if I'm not mistaking you want dd mmm yy) so when you try it again it is unable to find the sheets with the names corresponding to column A to replace them.
I solved this issue by specifying, in Excel and not programmatically, that the format of Column A is "text" instead of general and now it works well.
I hope that was your problem, if not, please provide more detailed descriptions, with the error you are getting (if any) so I can fully understand what is happening...
Personal advice: add some code in the CreateTOC macro to clear the content of column A if the user is allowed to delete sheets, otherwise you'll end up with unwanted names of none existing sheets in Column A.
You can use the range(x,y).ClearContents.
Regards,
Regards,
Good Answers: 204
01/13/2010 1:27 AM
GA
01/13/2010 3:08 PM
Good Call on clearing out the TOC Column A before updating the workbook again if a date or a sheet changes. Everything works great - I thought I tired the text format but guess I had it on general - which did not recognize it through the Macro.
Formatting the column A as Text resolved the situation.
Register to Reply 7 comments
chrisg288 (2); truchiller (3); wasaadeh (2)
You might be interested in: HPLC Columns, Gas Chromatographs, GC Columns
