Previous in Forum: My Laptop Hijacked   Next in Forum: LCD Video Cable Question
United States - Member - New Member Engineering Fields - Mechanical Engineering - New Member Popular Science - Weaponology - New Member Hobbies - Target Shooting - New Member Safety - ESD - New Member Technical Fields - Education - New Member
Component Video Question
01/12/2010 12:00 AM
I need help. I have a 6 wire output (SoG?), and a 5 wire input YRB+RW. What do I need to make this work?
Coming out of my device is six wires: Red, green, blue, yellow, red, white.
Going into the back of my monitor is: Red, blue, yellow, red, white.
It seems I have an extra RCA jack. What do I do with the green? Is that my sync signal? Will I have a green tinted image?
Please help me out guys, Have pity on an old mechanic.
-A-
question everything
Re: Component Video Question
01/12/2010 12:28 PM
What? Twelve hours later and no takers? I thought you fellers would have at least made fun of me by now!
-A-
question everything
Good Answers: 97
01/12/2010 11:25 PM
Where are you coming from and where are you going...
01/12/2010 11:54 PM
This would make sense if you had Red, blue, GREEN, red, white on your monitor. I think the video is red, blue, green (RGB component) and the other red, white are left+right stereo audio. My guess is the yellow on the device is Composite video, don't connect that. If your monitor really is Red, blue, yellow, red, white as you say, maybe the first three (Red, blue, yellow) are what is called YPbPr component video. You can connect these to the red, green, blue (RGB) video on the device, but I suspect the colours would not look right, however it would not hurt to try.
01/13/2010 6:36 AM
Like the previous post, sounds like you are confusing Component and Composite hookups. In either case, separate red/white are your audio connections. In the case of composite, a single yellow cable is used for video. Component cables are blue, red, green, tied together, generally much thicker than rca audio cables and used for hi-definition video signals.
01/13/2010 8:09 AM
Got it . Thank you guys.
The yellow input on the back of my monitor has a green inner circle I did not see previously.
The input is therefore either:
Red Blue Yellow/Green with red white (HD)
or
Yellow/Green Red White (SD)
That pretty much sums it up. Thanks again.
-A-
question everything
-A- (2); Anonymous Poster (2); bwire (1)
