Previous in Forum: power press capacity   Next in Forum: Elevators
Doubt on Power, Torque and RPM
01/12/2010 4:10 AM
Sir,
I have small doubt on Power and torque. What is the practical relation.I know power =torque X Omega. But when vehicl climbing up why we need more torque and As r.p.m increases,The torque increases up to certain value and then decreases??? how we can substantiate this statement and why clutch will be placed in between Engine and Gear box and why not between gearbox and Driven shaft..PLEASE HELP ME HOW THIS RELTION WILL BE..IT WILL BE GREAT HELP,IF SOME ONE CLEAR MY DOUBT
Re: Doubt on Power, Torque and RPM
01/12/2010 8:41 AM
Power=Jule /second
Jule=Newton*Meter
So power= NM/sec
NM= Torque
Power= torque/sec
Power=torque*rpm
This shows that when rpm increases torque decreases.
01/12/2010 8:49 PM
Or possibly even that Power increases???????????
01/12/2010 8:56 AM
But when vehicle climbing up why we need more torque -
More torque is required to give more power since you are working against gravity.
As you press the accelerator, more fuel is pumped into the engine, the engine power obviously increases, till it reaches its limit. Then the load power tries to overcome it (since you are at high gear and hence high RPM and the combined power required- potential+ kinetic is more than the engine can supply even at the full fuel feed and it now splutters. You reduce the RPM, the KE goes down as well as the PE (or rather Potential power) and the engine may be able to take this.
why clutch will be placed in between Engine and Gear box - Engine has to run. You want the minimum components along with it to run when not necessary.
01/17/2010 11:31 PM
Thank you very much sir
