Previous in Forum: Cavitation Technology for Saving Fuel   Next in Forum: Entanglements: Not Knot Theory
Streaks on Machined SS304 after Electropolishing
01/13/2010 4:33 AM
10 mm thick Flange was machined from a 12 mm thick SS 304 rolled plate. This was subsequently electropolished. A Streaky pattern is observed on the surface. The orientation of the streaks is same on both sides of the flange. These streaks/ patterns were not visible after machining & before electropolishing. They formed after electropolishing. Could any one tell me why it is caused & what can be done to avoid the same.
Re: Streaks on machined SS304 after electropolishing
01/13/2010 4:42 AM
What was the operation immediately prior to the electropolishing?
Was any surface grinding done?
There is a good possibility that the operation was done using a wheel that was previously used to machine/grind a CS or any other material with quite different Electropotential.
I have seen these in a lot of stainless steel components (of course not electropolished ones, rather components left for some times on LIFO system) where rust marks have formed due to imporper usage of grinding wheel. And these etch marks have surprisingly similarity with those.
Location: N.E. Alberta 55.6329 N Lat. 111.0729 W Long. Canada
Re: Streaks on Machined SS304 After Electropolishing
01/13/2010 8:23 AM
Kind of looks like dish washer streaks, like the acid wasn't completely rinsed off before drying.
Could be worse, it could be me. :)
Hobbies - Musician - New Member APIX Pilot Plant Design Project - Member - New Member
01/13/2010 9:59 AM
Chorium burn out.
A government big enough to give you everything you want, is strong enough to take everything you have.
Good Answers: 109
Re: Streaks on Machined SS304 after Electropolishing
01/14/2010 4:23 AM
Your SS is from rolled material (naturally, what else),
and you will see the internal structure after removing the deformed surface.
I experienced this very often on anodising.
I had examples where the grainy structure of either granular or lengthwise distorted crystallites of the metals was showing up as a beautiful black and white = shiny surface.
Try slight anodising with your material, may be you see something similar! (Submerged in your electropolishing liquid).
RHABE
01/14/2010 7:49 AM
I agree with Rhabe that the streaks are a result of the roller. It appears to me however that the electro-polishing (normalizing) process may not have been sufficient. I don't know a lot about it but it could have been a weak solution, improper current and or insufficient duration. I think that purchasing plate with a specified mill finish would help for the next run.
In my many years I have come to a conclusion that one useless man is a shame, two is a law firm, and three or more is a congress. - John Adams
Good Answers: 117
01/14/2010 10:06 AM
I got that once when I was using a brass wire brush in the pre-clean process. I switched to Stainless Steel wire brushes, and the problem went away.
Not saying this is your problem, but a check of the brushes and grinders for contamination might prove fruitful.
Register to Reply 6 comments
Anonymous Poster (1); mareng (1); mayt2u (1); nukesub629 (1); RHABE (1); Yusef1 (1)
