Previous in Forum: Technicial Note on Casting   Next in Forum: Turbine Speeds
Kinematic Equation for 4-Bar Linkage
01/13/2010 5:08 AM
Looking For Help to derive the kinematic equation for the 4-bar linkage shown; (to find the angular position of the cylinder at different values of theta )
Re: Kinematic Equation for 4-Bar Linkage
01/13/2010 8:35 AM
There are some good books regarding mechanisms that have the derivative equations for what you need. Take a quick search on one in a library near you. It is a basic academic calculation development that we usually see in mechanical engineering courses. Serves to understand the system and to be consulted when needed - not really to be known by hard, unless you work with it every day.
Humm... suspicious you are...
Good Answers: 183
01/13/2010 11:24 AM
To obtain the equations you need make a projection of the thick polygon on the 2 axis.
O1 is the oscillating center for the cylinder and O2 the one of the arm.
Because of the 90° angle between the piston centreline and the radius to the oscillating centre the angle "α" is also the angle between piston centreline and horizontal axis.
The angles with an "*" are those corresponding to the extreme position of the piston when its centreline makes 90° with "R".
Register to Reply 2 comments
