Previous in Forum: Machining Nylon   Next in Forum: Steel Plate Tolerance Specification
17 comments
How to Die-Cut Tyvek
01/14/2010 9:39 AM
I am looking for a way to consistently cut this material without leaving tiny filaments. This material averages ~8 mils in caliper but can range from 4-12 in any location. It is a high density polymer strand so it is also somewhat extensible. An incomplete cut results in the semi-cut piece staying with the web of material and becomes an unwanted part of the process as the web proceeds to the next step in the operation. Any thoughts out there?
Re: Die cutting Tyvek
01/14/2010 10:55 AM
Laser or water-jet cutting?
01/14/2010 12:37 PM
Hi. Can you post a close up image of the material? A thought could be a heated die that cuts and melts the part. It might get stuck in the die but the tool can have a ejecting core to spit each part out after the cut/melt.
"Remember... if women don't find you handsome, at least let them find you handy." - Uncle Red
01/14/2010 2:52 PM
The gasket industry and the paper industry both use steel rule dies.
01/14/2010 3:37 PM
The die cutting is done two different ways with same issues: male/female dies (tried different angle designs and concave) and with steel rule to poly anvil.
01/14/2010 5:36 PM
How many sheets are you cutting at a time?
How many sheets do you wish to cut at one time?
Automated system? I would assume yes. Are you dedicated to the process of die cutting, or open to other process?
01/14/2010 3:43 PM
I don't have a closeup of the material but it is used in different industries. You may have seen it in FedEx (untearable) envelopes or as a porous, water resistant material used in building as a house wrap. Kevlar is the material used in bullet proof vests. Tyvek is more important for being light weight and breathable yet very tough-hard to tear or puncture.
01/14/2010 4:10 PM
Sacrificial backing material or laser?
Re: How to Die-Cut Tyvek
01/14/2010 5:52 PM
Hey, I think I found something...
  • Tyvek® will stretch up to 30% before breaking. To minimize distortion or neck down during roll fed converting, keep tension less than 1.4 N/cm (0.75 pounds/inch.) A floppy web is recommended. This is particularly true when die cutting Tyvek® business forms with rotary punched sprocket holes.
  • Slitting, Sheeting, Cutting Because Tyvek® fibres are very strong, each must be completely severed; hangers will not break off. Knives, dies and punches must be set to close tolerances. A sharp, slightly rounded edge gives longer service than a pointed edge for crush cutting, but a sharp edge is preferred for other slitting methods.
  • Rotary Die Punching Because soft steel male/female rotary dies dull quickly when Set to the close tolerances required to punch Tyvek® cleanly, the use of rotary dies made of hardened tool steel or tungsten carbide is recommended. A list of manufacturers of these dies for Tyvek® is available from your Tyvek® Technical Specialist.
  • Die Cutting Tyvek® can be die-cut using either steel rule, male/female or closed dies. Tyvek® fibres must be completely cut and dies must be in good condition with sharp, nick-free edges. Dull dies cause edges to curl. When using closed dies, the use of a side cutter with internal relief is recommended. Deaerate and keep lift height below 7.6 cm (3 inches) when die cutting to avoid oversizing to blanks.
  • Punching Tyvek® can be punched on tag, letterpress and rotary line-hole equipment. Best results are obtained for sharp, well registered and closely fit punches. Punches may be either smooth or serrated and cut best if ground concave on the ends. A soft self-honing male punch in a hardened female die is recommended.
The entire FAQ sheet: http://www.polymernotes.org/resources/tyvekdupont.htm
Don't know if you found this page or not... pretty informative.
01/14/2010 6:28 PM
Freeze it just before it goes through the die cutter.
01/14/2010 7:03 PM
For a plethora of information about Tyvek, I suggest contacting Material Concepts, Inc. They are an authorized master distributor of Tyvek and offer a lot of information about the various types of Tyvek rolls, sheets, paper, fabric and graphics media on their website. Their phone number is 215-338-6515.
Results-Driven Industrial SEO and Web Marketing
01/15/2010 2:53 PM
I have spent 1,000 or more hours studing shear cut angles. It woud help to know what the cut looks like under a powerful microscope. How much is shear and how much is fracture. Since I do not know your process, probably some device to assure the cut was completed may help to avoid an uncut strand. You could either use visual or manual clearance assurance for each cut which would stop the process until corrected
Probably a rotary cutting is much better than a guillatine type cutting.
A manual arm moving downward after each cut would certify the cut was made, but I do not know how clean the cut needs to be. A study of the cross-section of the cut would help.
P E Bobimm
01/15/2010 2:56 PM
I would be happy to put you in touch with a company here in PA that has done some die cutting for us on a few Tyvek projects - all around the 7.5 mil range.
Please let me know!
01/19/2010 10:20 AM
oops... forgot to include my email or # if you wanted to get in touch:
1-800-372-3366 x 101 or Doug@materialconcepts.com
01/19/2010 10:36 AM
Hey there, MatCon Doug. Welcome to the forum.
It is usually not a good idea to give your email out... an open invitation to trouble.
http://cr4.globalspec.com/thread/45769/Why-You-Shouldn-t-List-Your-Email-Address
It may be a good idea to contact admin, and ask them to remove the phone number and email address. Members can contact each other thru the internal mail at CR4 with no exposure to outside interference.
01/19/2010 5:04 PM
Thanks for all the input. I have the DuPont information and have tried most. I will lookup Materials Concept and also will look at magnifying the cuts for better determination of mode of failure. We are focusing on the cutting die/anvil approach and looking for a good polymer to mount on anvil that will withstand 100's (1,000's?) of cuts without causing cut failures. Thanks again to all.
01/20/2010 9:56 AM
Hi dcquest - are you using a swing arm clicker to die cut?
02/06/2010 12:34 PM
We have built several systems to die cut Tyvek, Gor Tex, and other thin film media down to 1 mil. I'd gladly make you some samples from one of our test dies so that you can inspect them to see if they fit your criteria.
We were just in to a facility last week who is running a cutting system that we built several years ago. We were called in to replace their orignal system due to incomplete cut/fuzz issues. The have run over 10 million pieces and have not had to touch it. It is a problem we know how to solve.
mark@jencometal.com
Register to Reply 17 comments
Anonymous Poster (3); BlueHorseradish (1); dcquest (3); Doorman (3); JencoSolutions (1); lyn (2); MatCon Doug (3); oomsarel (1)
