1. How do you measure the airflow in a MUA or Exhaust duct? The existing range-oven requires 800 cfm MakeUp Air and Exhaust Air. Is there a device that one can place by the MUA outlet register, and the Type I Hood exhaust inlet filter to measure the velocity, and then convert this value to a flow rate, using the area of the duct or filter (Q = V * A) ? The new unit requires 1000 cfm.
2. The existing centrifugal upblast direct drive exhaust fan with 1/2 hp motor currently provides an 800 cfm flow rate at 1314 rpm. The manufacturer has stated it can be field-adjusted to provide 1200 cfm at 1500 rpm. I have interpolated to arrive at a 1000 cfm flow rate at 1407 rpm. I think it has a rheostat-type dial to vary the output.
3. The MakeUp Air is a dedicated evaporative cooler. I am told it can be wired for low, medium, or high output, to the maximum capacity of 3200 cfm. How can one determine the flow rates coincident with the settings?
4. The existing MUA outlet register has been installed inside the hood, a few inches in front of the Exhaust inlet filters. Is this common?
5. The Code requires the Exhaust duct flow velocity shall be at least 500 ft/min (IMC 506.3.4). The existing 9" square duct velocity at 800 cfm is 1420 ft/min. The new 1000 cfm flow rate in the same duct will result in a velocity of 1778 ft/min. I could find no maximum flow velocity. Is there a rule of thumb for max exhaust velocity?
