Previous in Forum: Harmonics in a 3-Phase Load with Open Neutral   Next in Forum: Pigtails and Electrical Drawings
Electrical Design Specifications
01/15/2010 1:16 PM
Greetings all,
iam working in an out door lighting design for our plant and i calculated the total watt needed (sum of all lights) = 53 kw, 220 volt
our power supply is 480V
so, I chosed a 75 KVA transformer dry type 480/220-127 V 3 phase 60 Hz
cable size from feeder to transformer primary = 50 mm2 (1/0 AWG)
cable size from transformer secondary to distribution panel board = 125 mm2 (250 MCM)
distribution panel board main breacker = 250 A
So, are my calculations ok ? any changes or suggestions ?
thanks in advance
Re: Electrical Design Specifications
01/16/2010 4:58 AM
How did u arrive at 75kva transformer? How did u get your power factor pf,how did u get your total load current? wt calculation using 480v or 220v?What criteria did u use to select your cable size of 50mm and 125mm for a 53kw total load?
If u are not very sure of your calculated values,consult a professional to do it for u or else provide a detailed information.
Patrick Whowha
Patrick Whowha
01/16/2010 8:50 AM
- power factor pf= 0.8, P(W)=IV * PF, the light source HPMV = 400 W, V=220 V, I=2.3 A
- transformer size => 75 KVA* PF = 60 KW, 7KW higher than needed KW
- calculation using 220 V
-cable size according to transformer max. capacity = 75 KVA, I= KVA/V, V= 480 Pri. & 220 Sec. => I= 156 A (Pri), 340 A (Sec)
load = 53 KW, but we may add loads in the future so I chosed cable size for maximum use.
- Iam sure about my calculations, but these are all using formulas and theory, I just wnna make sure that i did not miss anything.
reagards
01/16/2010 6:06 PM
(75,000 VA ÷ 480) ÷ √3 ≈ 90.2 A.
For conductors, 90.2 x 1.25 ≈ 113 A.
For this size of transformer primary CB is also (if memory serves) 90.2 x 1.25; the next standard size is 125 A.
And calculate similarly for the secondary. It looks as though the 1/√3 factor was missing from the original 3-phase calculations.
01/16/2010 11:28 PM
thanks a lot, i missed that one
01/18/2010 10:00 AM
I wouldn't rely on the cable rating alone (max amps). The more thorough method would be to make in-depth voltage drop calculations. Your posting indicates that all loads will be on a single circuit. Multiple circuits (multiple contactors and CBs) would lower the load on each cable, reducing min. cable sizes, thus reducing costs.
alsarey (1); Anonymous Poster (1); NoEngr (1); Patrick Whowha (1); Tornado (1)
